Best Type III Conversion Factory Parts
Moderator: Type 4 Unleashed
damo99
Post by damo99 » Fri Jun 13, 2008 8:58 am
can stufenheck or Angelo Amato please put some more photos of the conversion .as i'm also just about to start the type 4 into my fastback .i just need to look at the rear bar and the air bellow .
any pictures would help heaps
thanks damo
Angelo Amato
Post by Angelo Amato » Fri Jun 13, 2008 4:31 pm
damo99
Post by damo99 » Fri Jun 13, 2008 10:52 pm
thank you angelo for the photo's they are a great help to me and probably alot of other people who are doing this swap . the type 4 into type 3 is somthing the vw facory should have done .in australia i have only ever seen 1 fastback with a type 4 .but i have heard of a few others
thanks damo
Post by Piledriver » Sat Jun 14, 2008 2:18 am
Sweet...
CLH
Post by CLH » Sat Jun 14, 2008 11:13 pm
Looks (better than) factory Angelo, very nicely done.
ouvw2
Post by ouvw2 » Tue Jun 17, 2008 3:44 pm
Stufenheck,
I need your linkage. How do I get some. Who sells it?
Randy
Class 11 streeter
Post by Class 11 streeter » Tue Jun 17, 2008 7:08 pm
I am going to make this thread a sticky as the type 4 into type 3 conversion is not well documented in an easy to locate post. I don't think even our human search engine "David58bug" has this info.
Anyone finding a previous thread about the T4 into T3 please add a link to this thread.
Monte
Stufenheck
Post by Stufenheck » Wed Jun 18, 2008 1:03 am
Please note that this linkage set up was design by CSP for IDF with tall intake manifolds. The bellcrank is flipped in my installation. It is also does not provide WOT. If you are still interest here is information plus other parts required if using Weber DCNF's and short intakes.
The linkage is from CSP, it is there Type-4 Bellcrank Linkage for Porsche Fan System
http://www.csp-shop.de/cgi-bin/shop2/sh ... 8589717730
Purchase from: http://www.classicandspeedparts.com/ located in So Cal.
Also use Carburetor offset linkage arms from Gene Berg item GB 406A, http://www.geneberg.com/product_info.ph ... cts_id=835
Plus CB Performance item 3396 (2” Heim joint extension) to clear spark plugs wires, http://www.cbperformance.com/catalog.asp?ProductID=544
Angelo Amato
STICKY....
Post by Angelo Amato » Fri Jun 20, 2008 7:01 am
cool 8)
this thread has been made into a stick ! :wink:
Post by Piledriver » Sat Jul 05, 2008 11:02 pm
For one way of doing the linkage that's "guaranteed" to fit and work right...
(OK, OK, yes, it's DIY, but it can be EASY DIY)
You'll likely never buy a linkage again.
...Unless someone starts making these...
viewtopic.php?t=109159&highlight=cable+pull
blitzvw
Post by blitzvw » Thu Jul 31, 2008 5:29 am
A very informative post.
I'm about to embark on a Type 4 swap into my '68 Fastback.
As my rear valance was hacked by the PO, (was fitted with a WBX), I will be making a custom air intake out of fibreglass so that the fan can suck air in...
As I can't find a suitable 411/412/914 shroud, I will just drill the hole for the timing plug on the top of the Kombi shroud that I have. It should work :wink:
Angelo Amato
a few more pics...
Post by Angelo Amato » Fri Aug 01, 2008 5:53 pm
I remembered a camera so took a few more detailed shots.
you can see the bellows, t3/t2(t4) hanger mount adapter and also the solid mounted inner engine mounts.
Angelo
blitzvw
Post by blitzvw » Sat Aug 02, 2008 4:27 am
Cool! Thanks a lot for the pics. Now please take a few more videos of the car. Would love to hear how the car sounds! :lol:
Stefan T
Post by Stefan T » Sat Aug 02, 2008 11:43 am
Her's a altenative conversation off a type 3 with IRS
the big diffrence is that the engine and trans hangs only in engine hanger and the trans mounts
observ the M8 rubber mounts
the engine is hanged with OEM rubber rubber mounts + the extra rubber monunt and solid side mounts insted off type 3 mounts
The trans is a 914 with bug@5speed nosecone
The body off the car have no modifications for the conversatinon
[/img]
Post by Piledriver » Sat Aug 02, 2008 12:05 pm
Nice, looking to do this with the Piles old 1700 in a few weeks in a `73. (Will keep the CIS injection, I already installed CIS on the stock 1600DP in the T3 a couple of years ago)
Now to find a cooling intake adapter...
