Need info: T127 engine
Moderator: Type 4 Unleashed
Humby
Re: Need info: T127 engine
Post by Humby » Fri Aug 01, 2014 9:57 am
Here's a picture of the carb jets.
As you can see the venturi size is 28
Jets from left to right: 145, 050 and 105.
I also think that they were rebuild, or checked, because the upper gasket is one for a PDSIT 32-34 ...
Not sure if I will use the original carbs on this 127 engine, or 36IDF Webers...
Aircooled greetz,
Humby
dawie
Post by dawie » Sun Aug 03, 2014 4:25 pm
Thanks for the info. Any idea what size the main jet is?
Tony Z
Post by Tony Z » Mon Aug 04, 2014 12:44 am
Dawie
Call me and you can have a look at mine as closely as you like
vanapplebomb
Post by vanapplebomb » Sat Oct 08, 2016 7:59 pm
Anyone have any idea what kind of cam profiles the 1600 and 1700 127V engines ran in the supper vee class?
