DEUTZ 912 CYLINDERS
- petew
Re: DEUTZ 912 CYLINDERS
Will these only fit in a type 4 case or could you also fit them into a type 1 case?
- dstar5000
Type 1 cases cant accept a piston over 95mmm
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
will 2 cylinders with no fins on the touching side give you more room than 95mm bore,
basically 95mm + sleeves touching each other .
I am not saying they will cool well , just asking if they will fit ?
Then you have to worry about head stud spacing or move the studs......
- petew
Right, thanks for the info. I'm personally impressed you can do this with diesel pots. I've been wondering for years if it would be possible to build a 2 stroke type 1 using motorbike pots/pistons and heads.
There is a build thread on here back in 2001 or so of a guy in the midwest that made a 2 stroke out of a bug engine. He also had a bus automatic trans mated to it in a drag sand rail. Pretty cool.
Steve
My Baja Build
My Baja Build
- petew
Love to see a link to that!
I don't think these can fit a t1 case. You could also fit them on a oxtboxer/wasser boxer case.
- petew
Isn't the bore spacing the same as Type 1 on Wasser cases?
- sideshow
Bore spacing is the same t1-wbx, head studs get moved on t1 when 4" bore or the like.
IIRC, the biggest bore for a t1 was 98mm, and it required siamesed cylinders (ARPM/autocraft iirc)
From memory this setup was for 100% alcohol burning sprint cars and had minimal cooling fins.
For a T1 to be driven, 94mm is about it.
I’ve done a few 96mm piston/cylinder sets using the standard 4-stud layout. There are blank “thick wall 94mm barrels available now that can be bored to about 96mm, or maybe 97mm if you remove the slip-in section and machine a counterbore into the barrels to align them.
You can use Deutz barrels if you buy a blank case and machine your own studs and eliminate the oil passage going to the cooler.
Cal 67 i will be using a waterboxer case converted to aircooled with 10mm head studs. I would like to hear more about these 94mm thick sleeve liners, where did you get them, what brand and how much did you pay.
The largest I can go with 10mm studs is about 95.5mm. I have a nice, inexpensive hypereutectic piston with a small compression height that would work.
If I was you, I’d machine for some original 93 or 94mm Type 4 barrels, since you have a blank canvas after milling the jackets off. You could then bore them to 96. If you need help, contact me.
- CobraJet
Where can one go about obtaining a set of the Deutz cylinders nowadays?
