DEUTZ 912 CYLINDERS
Moderator: Type 4 Unleashed
dstar5000
Re: DEUTZ 912 CYLINDERS
Post by dstar5000 » Tue Dec 18, 2012 8:13 pm
Got a linky?
Don
Post by Piledriver » Wed Dec 19, 2012 3:59 am
dstar5000
Post by dstar5000 » Wed Dec 19, 2012 8:56 pm
Thanks guys! I posted these and other photos over there!
Don
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Dec 24, 2012 10:10 am
Hi there, have ya got any futher with this build,for my next build am gunna try some of these Deutz cylinders.66 x 107
dstar5000
Post by dstar5000 » Mon Dec 24, 2012 10:36 am
Yes, I got the rods narrowed, then had to narrow the Calico coated bearings because DPR
offset ground the crank with a generous radius for strength.
Comparison photo:
Chamfering rod after narrowing:
Trimming the Calico coated bearings:
SWINGING:
:D
Don
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Dec 24, 2012 4:13 pm
very nice.that crank looks tuff compared the STD 1. when do ya recon its gunna run.a youtube clip would be good. 8)
dstar5000
Post by dstar5000 » Mon Dec 24, 2012 9:42 pm
Checking my previous case clearancing job in the am. Probably have to touch
a few spots here and there but I originally was going for an 86mm crank, so I
might luck out and not have to do any more!
THEN I can check cam clearance......might be awhile, not getting in a hurry on this one!
:D
Don
GARRICK.CLARK
Post by GARRICK.CLARK » Tue Dec 25, 2012 6:19 am
Yep,always best to take ya time,Ive done mock up work on mine thought it was right,gone back to it after the week end only to find sumat not right. treble checking everything. c ya
andy198712
Post by andy198712 » Wed Dec 26, 2012 3:25 pm
Are you getting the rods end to end balanced after?
dstar5000
Post by dstar5000 » Fri Dec 28, 2012 12:16 am
GETTING? NO!
Am I DOING them?
YES!
:D
Actually, I DID them yesterday! .4 grams from lightest to heaviest.....
Don
dstar5000
Post by dstar5000 » Fri Dec 28, 2012 12:20 am
Today, I made a gear puller to take th gear off the old crank:
EASY PEASY and no damage to gear!
JOB DONE!
:D
Don
andy198712
Post by andy198712 » Fri Dec 28, 2012 10:45 am
dstar5000 wrote:GETTING? NO!
Am I DOING them?
YES!
:D
Don
Cool!
how did you do it?
took me ages to perfect my jig to balance mine :roll:
dstar5000
Post by dstar5000 » Fri Dec 28, 2012 8:16 pm
I made a swing and used my Craftsman laser level to set it the same everytime!
:D
Don
dstar5000
Post by dstar5000 » Sun Dec 30, 2012 7:56 pm
EVERYTHING TURNS WITH NO INTERFERENCE!
Cam is only .500 lift so the rod misses it by .035".
Measuring to cut the cyls to length now:
DON
Steve Arndt
Post by Steve Arndt » Sun Dec 30, 2012 8:31 pm
With your budget it seems you would have LN cylinders.
I really like the fins on the square tractor ones! When I finish with my 103 Eurorace cylinders I may go this route.
edit;
Damn those cylinder bases on the case are thin. My 103 bored case has about twice that material remaining.
