Alternator stand
Moderator: Type 4 Unleashed
jan72
Alternator stand
Post by jan72 » Sun Jul 03, 2011 12:14 pm
Hi, is there still someone selling an alternator stand for the upright cooling? I mean other then Jake Raby's stand, which needs to be modified when used with the type 1 shroud...
Thanks.
sideshow
Re: Alternator stand
Post by sideshow » Sun Jul 03, 2011 11:38 pm
I can only think of two upright kits (excluding DTM/Porsche and Porsche'ish);
Imagehttp://www.sharpbuilt.com.au/sharpbuilt1/page11.htm VW STYLE TYPE IV FAN KIT
and
CSP's ww.csp-shop.com/cgi-bin/cshop2/front/shop_main.cgi?nocache=1309754010&func=det&rub1=Products&rub2=Engine,Cooling%20System&artnr=13261b# Type-4 Upright Conversion
Neither seem to offer ala'carte
Post by Piledriver » Sun Jul 03, 2011 11:46 pm
It's really not that hard to make one from scratch from Nextgens directions.
I used Bay Bus rear seat "T" bolts as the clamp//connection between the cut down T1 stand and the 1/2" aluminum base for extreme adjustability.
No welder, just sawzall/file/drill. Has never moved AFAICT.
No, it doesn't look "factory". Works was my only priority.
SOMEONE was fabbing some nice welded units awhile back, but I have slept since then.
jan72
Post by jan72 » Mon Jul 04, 2011 4:17 am
Not hard to make one, indeed, but i was shooting for the factory look :). I made one for the vanagon case which is in service now, but i'll be using the open breather style case.
Someone was making a nice (very) adjustable one, but i can't remember either.
I'll look for a Type 1 stand and see what comes out without welding...
Post by Piledriver » Mon Jul 04, 2011 4:42 am
Ran it through search, Nate and speedy57tub were working on stand designs at one point, might want to check with them for updates.
Sharp's kits are pretty reasonable, and the shipping didn't look as bad as I expected.
The stock T4 oil cooler location option is nice, should fit late cars fine.
If (when) I do another upright I'll probably try to track down the "tins" in FG, IIRC someone was making just the "tins" for a sane price, or talking about it, you know how that goes.
OTOH I've been looking at making a horizontal 914 cooling setup using a T1 fan... that sucks up from underneath and exhausts out hoses on top, rather than blows down, as bottom up is how the airflow wants to be on a 914. (even if the cold air gets ducted in from NACA ducts on the rockers, there's ~actually room for it, maybe)
Note:that is strictly an exercise in curiosity leaning towards the deranged.
It could also be used as a leaf vac.
dstar5000
Post by dstar5000 » Tue Jul 05, 2011 2:21 am
A newish Mexi-stand has more room and usually hasn't had as many years of grease absorbed
into the metal...
Don
NextGen
Post by NextGen » Tue Jul 05, 2011 12:44 pm
You do have to be careful some stands are Magnesium and not Alum.
Hit it with a torch and you will be in for a big surprise.
If you go to my site you will see my stand , was welded and looks stock!!
jan72
Post by jan72 » Tue Jul 05, 2011 1:32 pm
No problem, i can tell the difference. I'm trying to avoid the welding part...
Gnasha
Post by Gnasha » Thu Jun 22, 2017 8:25 am
Iv'e been collecting the bits needed for a conversion including a alt stand. Now Ive just read that some are Mag and some Alum and some weld better than others.
Q: before i start cutting and chopping ready to weld, how can I tell the difference between the two?
Gnasha
Lo Cash John
Post by Lo Cash John » Thu Jun 22, 2017 12:09 pm
Gnasha
Post by Gnasha » Fri Jun 23, 2017 8:32 am
Thank you for the link that was brilliant, now, if i have to purchase another stand how can I ensure its Aluminium? model, year Mexico parts? part number?
Thanks again much appreciated
Lo Cash John
Post by Lo Cash John » Fri Jun 23, 2017 9:24 am
Any new stand you buy now will be aluminum. Mag stands were from the 60's or early 70's as far as I know.
Arnoud
Post by Arnoud » Fri Jun 23, 2017 4:02 pm
Post by Piledriver » Fri Jun 23, 2017 7:55 pm
Best idea, that price includes VAT, so it should run about that shipped to the US. (no VAT)
English link:
https://www.csp-shop.com/en/brand-shops ... 2731b.html
Sadly CIP1 doesn't carry the CSP conversion parts in the US, just some of their T1 bits.
http://www2.cip1.com/SearchResults.asp? ... =20&page=1
