Cheap Junk 1971 Build
Moderator: Type 4 Unleashed
oprn
Re: Cheap Junk 1971 Build
Post by oprn » Sat Mar 31, 2018 4:21 pm
In the hole.
oprn
Post by oprn » Sat Mar 31, 2018 4:23 pm
Getting closer to done!
oprn
Post by oprn » Sat Mar 31, 2018 6:54 pm
Now for a spot to pick up the oil pressure. Can't tee into where the pressure switch goes as it would be in the way if the distributor so down on the rear where we plugged the galleries. Hard pipe it out to where we can deal with it.
Gnasha
Post by Gnasha » Sun Apr 01, 2018 6:54 am
Great progress. Loving the new pipe work, neat and tidy job, and soooo shiny :)
oprn
Post by oprn » Sun Apr 01, 2018 8:22 am
Thanks! Stainless steel, someone dumped a whole crap load of 1/4" ss tube fittings on us at work. The boss threw most of them out at inventory in January but I saved a few for just this sort of thing!
Gnasha
Post by Gnasha » Sun Apr 01, 2018 8:34 am
I'm also a hoarder and a saver from the local skips at work. So much stuff I don't have enough room for the, "that may come in handy" pieces i see at work. :roll:
oprn
Post by oprn » Sun Apr 01, 2018 6:02 pm
I hear ya load and clear! Handy at times though, I have salvaged 5 temp indicators with discreet set-able contacts to use for alarms, each have 2 channels and will work on 12 volts. I will be using 2 of them in the Buggy. Now I have an acceleration transmitter and 3 different indicators that are compatible with it and work on 12 volts. This I hope to use as a detonation indicator. I have various lengths of lighter gauge 4 wire Belden cable, thermocouple wire, thermocouples and RTDs to hook it all up, all salvaged from upgrades and headed for the trash!
Can't get in my garage anymore! That's the downside...
oprn
Post by oprn » Sun Apr 01, 2018 6:09 pm
Finally found my pulley for the thermostat but can't find the bolt... now that I think of it though it may not have had a proper bolt in it. I do recall the pulley being very loose and there appears to be no wear on the bushing.
Looks like a lathe job coming up.
oprn
Post by oprn » Tue Apr 03, 2018 9:24 pm
I was needing some place to mount my fuel pressure regulator and to bring the two choke cables from the carbs to so that they can be operated by a single pull cable from the driver's seat. This is the solution I came up with, a flat plate bolted onto the stock air cleaner support brackets. Regulator goes underneath and gives me a nice flat spot to start building the choke mechanism.
Post by Ol'fogasaurus » Tue Apr 03, 2018 10:27 pm
Nice!
oprn
Post by oprn » Sat Apr 07, 2018 2:14 pm
First prototype of the choke linkage using bicycle cables for the carb side and a lawn mower throttle cable for the driver's side. Just need to engineer a spring clip to keep the two bike cables from popping out sideways.
oprn
Post by oprn » Sat Apr 14, 2018 5:54 am
Here is the conclusion of my attempt at a choke cable solution.
oprn
Post by oprn » Sat Apr 14, 2018 6:01 am
I posted the wrong picture of the center splitter, no clip so this is the one with the clip.
oprn
Post by oprn » Sat Apr 14, 2018 10:06 pm
Took the Buggy for one last rip then out with the old!
oprn
Post by oprn » Wed May 16, 2018 6:12 am
New engine is in and had a couple start ups a minute or so long. Lots of oil leaks, about 1/2 the push rod tubes are dripping a bit on the outer ends. Is this common? My flywheel seal is leaking a bit too but I am not too surprised as the flywheel itself had a bit of a wear mark where the seal runs.
