I ran into the same issue, but if you can PLAN the build using the step AS deck, its no huge issue.Type 4 Unleashed wrote:Let me put it this way, what do you think a .040" or even a .035" step cut in the heads will do, I hope you don't think it will make them stronger ?
Here's a link to a set I bought that had a step already cut, but the step was cut to reduce the CR since the heads were intended for a Turbo build. Now I am stuck with the step, and very reluctant to remove it. And wish it hadn't been cut.
viewtopic.php?f=1&t=121608
It does very much suck to be surprised by it when you pull the heads out of the box.
That's the only reason I'm running .055" deck, the bottom end was done, and I didn't want ~.035 deck bad enough or need the CR bump to have the jugs cut or case decked, the current cam works OK with the resulting CR.
With no step or shims I'm at .020", +.035" step cut.
The "turbo" heads I acquired were step cut AND semi-Hemi cut, but I solved that with some custom JEs with a matching dome, so i actually have more squish area than I would with flat tops, and a very compact chamber space. The motor those go on will not be high boost, I have a better plan for that. ..
