When a 3Ltr.Type 4 just wont do...
Moderator: Type 4 Unleashed
Arnoud
Post by Arnoud » Fri Jan 13, 2017 2:19 pm
Then it's good to know that Edi Remmele has got you covered:
http://bugfans.de/forum/motor-typ4/typ- ... 15967.html
Five bearing crank 115mm bore 96mm stroke camdrop etc..
Start saving :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Distance between bore centres are 124.5mm,in wetsump form 6ltr oil.
From the German VW-forum: http://bugfans.de/forum/motor-typ4/typ- ... 15967.html
CobraJet
Re: When a 3Ltr.Type 4 just wont do...
Post by CobraJet » Fri Jan 13, 2017 9:20 pm
Where do I drive my dumptruck full of dollars to buy that one?
Type 4 Unleashed
Post by Type 4 Unleashed » Thu Jan 19, 2017 3:26 pm
I only see 4 main bearing saddles and 3 cam bearing saddles ? 115mm is a 4.5" bore. The bore spacing could be changed and still run Type lV cranks and cams. The dropped cam would only need a larger gear set. Pauter Big Block motors have a dropped cam. I have been running the translation program, and it's still running so I haven't been able to read the topic.
Remember these cylinders 111.125mm-4.375" Bore: viewtopic.php?f=1&t=108461&p=779408#p779408.
Richard
EMW
Placerpuma
Post by Placerpuma » Fri Jan 20, 2017 12:39 am
Google Chrome has a translate option, but you have not missed much at this point of time Richard, mostly people congratulating Edi Remmele on the new project. He certainly is a very talented builder.
Arnoud
Post by Arnoud » Fri Jan 20, 2017 10:21 am
Type 4 Unleashed wrote:I only see 4 main bearing saddles and 3 cam bearing saddles ?
Hi Richard!
Now that you mentioned it:indeed!only four bearings.But in his own comment Edi mentioned five(?)
He also mentions a cam drop.He has got his own Biral-liners.
If I read his comment right then this is a tryout to see if they can machine a case from scratch.In 96mm stroke form
it will then have five bearings.I wonder if this is a crank from a existing production enigine?
Regards,Arnoud
Type 4 Unleashed
Post by Type 4 Unleashed » Fri Jan 20, 2017 3:33 pm
Hi Arnoud
I have Google Chrome, and is the translation program I am running, but it runs & runs, never completing.
The current case he's machining I just don't see five, and I don't see him spending double to do another case ?
So will have to wait and see how the case develops.
Pauter does a 96mm stroker for his Big Blocks, same amount of bearings.
Richard
EMW
Post by Piledriver » Fri Jan 20, 2017 7:32 pm
Maybe he doubles up the snout bearings to better drive a blower?
E_bug
Post by E_bug » Tue Apr 10, 2018 3:30 pm
Any news on that 3L ?
My welding sucks .
