Break in procedure and response guide
Moderator: Type 4 Unleashed
cgates30
Post by cgates30 » Thu Oct 12, 2017 6:38 pm
I've done a little searching but haven't found the level of detail I'm looking for. Is there a guide that recommends a break-in procedure with as response guide on what do "if" for a newly rebuilt T4. Sorry if I just missed it..
Sent from my Nexus 5X using Tapatalk
cgates30
Re: Break in procedure and response guide
Post by cgates30 » Sat Oct 14, 2017 11:01 am
This is what I've found: http://www.aircooled.net/vw-engine-break-in-procedure/
Under the preparing to run section, it says to remove the oil pressure switch and spark plugs except for the Type 4. For a type 4 it says to remove the spin on oil filter.
In the running the engine the first time section, it says to run between 2000-3000 rpm for 15 minutes. I recall from other forums seeing it should be at 2000 rpm for 20 minutes. Are these guidelines or hard and fast rules? If hard and fast, which one is right? They give a little explanation for the reason for 2000+ for breakin, but don't really address how much rpm/time is actually needed. Is it a case where 2000 rpm at 30 minutes would be even better for cam lobe and lifter break-in?
They also say to adjust the valves every 500 miles for a new engine. Does that sound right?
analogtherapy
Post by analogtherapy » Sat Oct 14, 2017 7:16 pm
I've not actually gotten to that point yet in my own rebuild, but I can say that I've found similar information. There seem to be 2 specific break in periods: 1) When you're starting the engine the very first time, and 2) when you actually start driving it.
Here's some more info from another respected vw mechanic: http://www.itinerant-air-cooled.com/vie ... php?t=7709
Good luck!
cgates30
Post by cgates30 » Sun Oct 15, 2017 4:59 pm
Thanks for the link. The more I can learn the better!
