t4 oil pumps
Moderator: Type 4 Unleashed
neilb
t4 oil pumps
Post by neilb » Sat Feb 24, 2018 7:30 am
just gathering peoples thoughts for a new (as factory spec) cnc t4 oil pump. would it be worth it having a run made?
patto
Re: t4 oil pumps
Post by patto » Sat Feb 24, 2018 6:42 pm
I think thats a great idea considering the challenges of setting up the alternatives to suit! Orratech? do a CNC pump but is very pricey, if you can keep the costs reasonable it shouldn't be a problem selling them.
Do you intend to manufacture in Australia?
wreck
Re: t4 oil pumps
Post by wreck » Sat Feb 24, 2018 6:43 pm
Thats an interesting idea , just get the alloy body made like a type 1 but with the type 4 OD and spacing, so new shadeck gears fit ,hopefully in 26mm and 30mm. Depending on cost I'd buy one just to have on the shelf .
dunegoon
Re: t4 oil pumps
Post by dunegoon » Sun Feb 25, 2018 1:50 am
Mostly, make the pump OD correct, not loose like the Shadeck.
neilb
Re: t4 oil pumps
Post by neilb » Sun Feb 25, 2018 2:17 am
thank guy's, i have drawn up the pump housing already, i have to see a machinist i know in melbourne to produce the shafts and gears. these would be made in melbourne by the same machinist who is looking at the gears. it would be as OEM spec regarding the gear sizes and the other specs/tolerances.
i don't know what the total cost would be but if this does go ahead anything posted within aus would probably be free
Eddie010
Re: t4 oil pumps
Post by Eddie010 » Sun Feb 25, 2018 3:48 am
http://www.adv-performance.de/Eigene%20Produkte.html
i bought this one. Nice cnc pump.
ps also bought their h rods for my 76.4 welded crank (55mm taps)
Andy Somogyi
Re: t4 oil pumps
Post by Andy Somogyi » Sun Feb 25, 2018 12:33 pm
I’d be very interested in a Type4 dry sump pump, at a reasonable price.
I’ve looked at the CB performance, and I don’t think the scavenge side is big enough.
The $1500 Moroso ones are way overkill, not building a NASCAR engine here.
patto
Re: t4 oil pumps
Post by patto » Mon Feb 26, 2018 5:49 pm
Andy have you seen this Dry Sump from Thorsten?
http://www.tp-technologie.de/products_d ... l_pump.htm
Andy Somogyi
Re: t4 oil pumps
Post by Andy Somogyi » Tue Feb 27, 2018 3:44 am
I have seen the Thorsten pump. Nice pump, but that’s a lot of money for it.
I might end up going with his, or if I can talk our machine shop supervisor into letting me use the CNC, I might end up making my own.
neilb
Re: t4 oil pumps
Post by neilb » Wed Feb 28, 2018 2:56 am
i measured the gears in my pump and they measure just over 30mm well 33.14. it's not possible to to measure straight across as the teeth are not in line. so i measured the center bore, then measured from the top off a tooth to the inside edge of the center bore, the added that twice as it's a rotating mass.
any comments?
neilb
Re: t4 oil pumps
Post by neilb » Wed Feb 28, 2018 9:23 pm
don't worry, it's the height not width lol
Type 4 Unleashed
Re: t4 oil pumps
Post by Type 4 Unleashed » Thu Mar 01, 2018 6:58 pm
As to Dry Sump pumps, had you looked at Autocraft ? http://www.autocraftengines.com/oil_control.html
Or the Pauter ? http://pauter.com/parts/oil-pumps/
Richard
EMW
Clatter
Re: t4 oil pumps
Post by Clatter » Sun Mar 04, 2018 10:20 am
I'm thinking that you would tool up to make a run of pump bodies, and people could use gears from another pump..
1. There's tons of old gears around, and they don't usually wear out, it's the bodies that wear.
2. Make them for a type 1; Much larger market.
3. Those of us who want to run the pump in a type 4 can do the mods needed.
It's not the most difficult part ever made,
But there are going to be a few ops needed..
- Doug Ellsworth
neilb
Re: t4 oil pumps
Post by neilb » Thu Mar 29, 2018 5:08 am
originally that is what i am doing, i have designed a new style internal gears to run in those pump bodies, and my machinist is talking with an engineer at his works regarding those.
the drawing is finalized and he is doing a quote for me as we speak. i would imagine since it's thursday evening it will be after the easter break
