Turbo type4 fastback:)
Moderator: Type 4 Unleashed
Post by MASSIVE TYPE IV » Sun Dec 30, 2007 7:33 pm
One day...
People will listen...... How many failures does it take for people to get the point??
Amazing.......
There is no failure worse than a flat cam, I have my share of those experiences, but those 18 months of development were worth the time and expense.
I feel your pain as well.....
I'd like to know what cam blank Web used to grind this cam, if it was integral the problem has been discovered... EVERY one of those I tested failed in less than 3 hours in the spin device.
Web's QC has slipped a bit in the past year and I have moved the majority of my cam grinding in house, only using Web for the 11 grinds of theirs that are "theirs"....
Passatman
Post by Passatman » Sun Dec 30, 2007 9:55 pm
jonas i suggest you stop wasting time and buy a cam and lifter set from jake.
jonas n
Post by jonas n » Mon Dec 31, 2007 4:30 am
I think you´re right there Passatman, I just need to save some money first..
Svwerker
Post by Svwerker » Mon Dec 31, 2007 7:09 am
Frallan wrote:Svwerker, you are on very dangerous grounds with your statement, even if you have a smile....:)
This is not just a website thread, it is as close to religion as you can get.
Be very careful....I know you well from all the Vdubs videos but I am not sure you know me too well by face?
One day we will meet at a VW event, will be fun to discuss TIV versus T1, right:) I will keep my smile.
I know, religion is like childsplay compered. :lol: We have met at JPM's Dynoday, Frallan, and I will also keep my smile!
I know Jonas to well not to comment this, his a funny man. No hard feelings, right?
I feel bad for every engine that fail. There is no joke about that!
fastback
Post by fastback » Mon Dec 31, 2007 7:31 am
BAd news....
I asume u checked the cam/lifter geometri to avoid the cam riding on the edge of the lifters??
interresting because:
Yesterday i torn apart a Type 4 that a friend of mine had just bought .
with only 1000km on it. using a cam that was stated "~301" total duration.
It had a "14" stamped were the camgear sit's.
When looking at the cam. there was only intake that was worn
it had a much more lift than the exhaust that was more or less the org shape.
there is only the area where two of the 4 lifters make contacton the sam lobe that was worn down.
What could be the possible cause of this??
could it be tolerance differences in the location of the liftebores on each crankhalves that makes the lifters not getting the same geometry?
If so you'd have to check each and every lifter/cam lobe for it's geometry?
it looked like this.
jonas n
Post by jonas n » Mon Dec 31, 2007 12:08 pm
Damn Fastback, thats the flattest cam i have ever seen :shock:
Svwerker, you know there´s no hard feelings:) Looking forwart to meet you guys again:)
Post by Piledriver » Mon Dec 31, 2007 3:42 pm
XXX can snuff shots. Ugh.
I wonder if the cam edges were originally sharp or properly relieved... The sharp corners like to break off, they are very brittle, and very, very hard.
Passatman
Post by Passatman » Mon Dec 31, 2007 8:31 pm
jonas n wrote:I think you´re right there Passatman, I just need to save some money first..
Jake now has a new system for selling his cams. You get the whole valve train assembly in the kit. Jonas need to see this car back on the road.
func412
Post by func412 » Tue Jan 01, 2008 9:54 am
fastback wrote:Yesterday i torn apart a Type 4 that a friend of mine had just bought .When looking at the cam. there was only intake that was worn, it had a much more lift than the exhaust that was more or less the org shape. there is only the area where two of the 4 lifters make contacton the sam lobe that was worn down.
Looks bad!
Just guessing...
Were the original pushrods used? I can just guess, but there is a possibility that the pushrod wasn´t installed right. I´ve installed twice the original pushrod incorrectly: the tip of the pushrod didn´t reach the bottom of the lifter cup because the wall of the pushrod contacted the lifter cup edge. Because of that the valve clearance might have got loose when running the engine (the pushrod tip reached the bottom of the lifter cup in use) and caused that failure. If the valve clearance is that loose, it might beat that lifter and break it.
Blitzkrieg_Beetle
Post by Blitzkrieg_Beetle » Sat Mar 01, 2008 3:48 am
Hey jonas n
I really like your Fastback, I have two at home, both of which are not running...
Do you have any updates for us? My Fastback will also be running a Type 4 engine :wink:
jonas n
Post by jonas n » Sun Mar 02, 2008 2:48 pm
No major updates right now, but i hope i get the projekt going again later this spring..
bo
Post by bo » Sun Jun 22, 2008 11:25 am
ok its summer where you at? :?:
Class 11 streeter
Post by Class 11 streeter » Sun Jun 22, 2008 12:49 pm
bo wrote:ok its summer where you at? :?:
Hey stranger, we could say the same about you! :lol:
How's it going?
bo
Post by bo » Sat Jun 28, 2008 9:43 pm
DOING ALRIGHT THE BUG IS ALL STRIPPED DOWN TO NOTHING MY MOTOR IS NEEDING HEADS AND THE CAR SHOULD BE PRIMED SOON
fastback
Post by fastback » Tue Aug 19, 2008 4:39 pm
jonas n wrote:Yep! the 2:nd gear is now the first:) I´ll take some pics someday to explain why i had to modify the slider..
Hi jonas
Do u hve pic's of the finished modified slider?
I'm just in the startphase of making the same!! :)
