Turbo type4 fastback:)
Moderator: Type 4 Unleashed
jonas n
Re: Turbo type4 fastback:)
Post by jonas n » Sat Jan 21, 2017 11:46 am
Well i have to get you updated now, the plan right now is to get the car running,to join the Carbage Run Scandinavia this summer. It's a kind of roadtrip for cars at least 15 years old, with a value about €500($500). The distance to drive is 3000km(1864miles) in five days through seven countries. We signed up with the fasty and just have to put it together as a more streetfriendly car.
jonas n
Post by jonas n » Sat Jan 21, 2017 12:04 pm
Started to put the old type4 together as a N/A-motor. 94mm flat top pistons, 42x36 valves, mild cam i got from a friend. All things balanced and of equal weight.
jonas n
Post by jonas n » Sat Jan 21, 2017 12:23 pm
We are actually going FROM turbo, megasquirt and pointless ignotion TO carburetor and points! Back to basic, simple constructions and reliability is highest priority!
TZepeSH
Post by TZepeSH » Sat Jan 21, 2017 1:15 pm
Are those ARP bolts on the connecting rods? If yes, what part number?
jonas n
Post by jonas n » Sat Jan 21, 2017 1:38 pm
ImageStock rods with 22mm bushing and arp-bolts, if the parts was bought today i would have bought some lighter h-beams.
jonas n
Post by jonas n » Sat Jan 21, 2017 1:42 pm
Don't remember the part nr for the bolts, they are ARP and they cost a fortune back in 2006:)
TZepeSH
Post by TZepeSH » Sat Jan 21, 2017 2:09 pm
OK, thank you. I'm looking for some ARP bolts that do not need expensive machining to install. I don't know if there are such bolts that would fit without machining.
Post by Piledriver » Sat Jan 21, 2017 4:47 pm
TZepeSH wrote:OK, thank you. I'm looking for some ARP bolts that do not need expensive machining to install. I don't know if there are such bolts that would fit without machining.
Anytime you replace the bolts the big end is supposed to be resized, as the bolts are a interference fit.
You may get away with it, but you go first.
You can get a set of much better ARP2000 wave-loks and nuts (2 sets for us actually) for a 396 chevy for less than the stupid expensive "correct" ARP bolts but the bolt holes will need reamed a few thou.
TZepeSH
Post by TZepeSH » Sun Jan 22, 2017 2:36 am
Thanks for the clarification Pile. I now understand why the big end need to be worked on.
Do you know the part numbers for the "Correct bolts" and for the Chevy bolts? I found several part numbers, some for same numbers for 1.7 rods and 1.8 and 2.0 rods, so it's confusing. 104-6006 seem to be too short, for 1.7l rods, 235-6402 might be the ones for Chevy, can 104-6004 be the "correct" ones ?
Sorry to hack your thread Jonas.
Post by Piledriver » Sun Jan 22, 2017 1:11 pm
~Same as T1 rod bolts, 104-6006 fits all T4 rods, but DO shop hard, as prices vary wildly.
The 235-6402 are the arp pro 2000 but even the dirt cheap 135-6402s are somewhat stronger than the vw bolts due to wavelok design.
RIMCO uses a super duty Carrillo bolt that is allegedly a direct stock replacement but nobody had figured out the part# yet. It uses the 300,000 PSI CARR proprietary SS material which makes ARP2000 look worthless and weak.
RIMCO will merrily exchange your stock rods for their "Super rods" which are stock rods, balanced and optionally clearanced, with those bolts... Don't see them on their website but AFAIK they still do them, but IIRC pushing the cost of EMW Hbeams.
The arp2000s come with nice light 12 point nuts.
I bought a set years ago, sold half, and have been looking for the rest since :oops:
By the time you get the bolts and machining and rest of rod rebuild done, Hbeams start to look really practical.
Consider the Dodge rod bearing mod as well: should be ~no extra cost if the rods are being resized anyway, nd as long as you are std or first cut on the crank the awesome Clevite K series bearings are an option.
Even if crank is on cut 2+ there are excellent rod bearings available, cheap, anywhere..
jonas_linder
Post by jonas_linder » Mon Jan 23, 2017 12:36 pm
jonas n wrote:We are actually going FROM turbo, megasquirt and pointless ignotion TO carburetor and points! Back to basic, simple constructions and reliability is highest priority!
Don't call me when you crawl around in the gravel looking for your small brass-thingies for the carburetors :roll:
Oh.. wait.. you were the one saying that :lol:
How many times did MS actually break down in the fastback? :)
Wally
Post by Wally » Mon Jan 23, 2017 3:00 pm
double post
Wally
Post by Wally » Mon Jan 23, 2017 3:01 pm
Garbage run? Worth 500 euros? Heck, I'll give you double that for the fasty!
Good points! Pun intended :lol:
jonas n
Post by jonas n » Tue Jan 24, 2017 2:00 am
I know i said that! :D
I'm not worried about the MS itself, it actually only broke down once...in the milde of the Woods...where no phones worked :lol: . But to be safe about i't i need to install it better. The guys im going with gave me turbo-prohibition anyway :roll:
The rules were not that hard,old and rusty was ok :D i actually bought the fasty for €700, think it was in 2004...
Wally
Post by Wally » Sat Jan 28, 2017 6:38 am
jonas n wrote: The guys im going with gave me turbo-prohibition anyway :roll:
I would change friends :lol:
Does the fasty have IRS?
Nice to see it being build-up again though :D
