Can you name the parts of the cooling tin?
- david58
- volkaholic1
Re: Can you name the parts of the cooling tin?
What is the prize for correct identify of the parts? I got 52 out of 55, for a 94.5%, do I get an "A"?
1 - dual port cylinder tin
2 - ?
3,12,19,22,27,31,35,40,46,53 - washer for cheese head screw
4,13,18,21,28,32,36,41,47,54 - 6MX1 cheese head screw
5 - cyinder air deflector
6 - heater box tin (sled), 1/2 cylinder, upper
7 - stale air heater box tin (sled) 1/2 cylinder side
8 - stale air heater box tin (sled) 3/4 cylinder side
9 - heater box tin (sled), 3/4 cylinder side
10- heater box tin (sled) 1/2 cylinder side, lower
11- lower air (heat) deflector, #4 cylinder
14- stale air heater box flap, 1/2 cylinder side
15- stale air heater box flap, 3/4 cylinder side
16- ?
17- doghouse oil cooler exhaust, lower
20- doghouse oil cooler exhaust, upper
23- doghouse firewall tin, front tin, forward tin
24,26- grommet
25- plug
29- gasket
30- big pulley tin, rear pulley tin, rear breast plate
30a,34 - plug
33- small pulley tin, pulley tin, crank tin
37- doghouse oil cooler exhaust seal, upper to lower
37A - doghouse oil cooler exhaust seal, lower to firewall
38- crank nut cover
39- there is no 39 on this page
42- carb preheat hose seal
43- dual manifold preheat pipe insulator
44- single manifold preheat pipe insulator
45- thin inner part of dual manifold preheat pipe insulator
48- heater hose rubber grommet
49- manifold preheat pipe insulation
50- manifold preheat pipe insulation
51- manifold preheat pipe insulation
52- manifold preheat pipe insulation
55- ? does not indicate where it is located
Now that you know the names, if you need it powdercoated, I can help you out. www.awesomepowdercoat.com
2 - ?
16- ?
24,26- grommet
25- plug
29- gasket
30a,34 - plug
38- crank nut cover
- volkaholic1
Oh, and then there are the parts not shown in the diagram
- the fan shroud
- the 3 piece alt/gen backing plate set
- the #2 lower cylinder tin hot air deflector
- the carb preheat "stove pipe"
if they are going to show the stale air heater box tin, they might as well include
- single port cylinder head tin
- early firewall tin
- the fan shroud
- david58
I give you a A+ for effort. Nice job, and Thanks. I wish we had a video showing the engine tin being correctly installed on a type one, even if it was just a slide show naming the parts in order they need to be installed.volkaholic1 wrote:What is the prize for correct identify of the parts? I got 52 out of 55, for a 94.5%, do I get an "A"?
Now that you know the names, if you need it powdercoated, I can help you out. http://www.awesomepowdercoat.com
- volkaholic1
you know, that's not a bad idea. Let me see what I can do.
Oh, and let's not forget the thermostat flap system! although it techniquely is not "engine tin" it should be included.
Such a resource would be real kool for us newbies!
I have 1967 body parts for sale.
- sideshow
2- Threaded/captured nut in the square hole
16- Is an anti rattle rubber much like a gas door bumper
55- looks to be a throttle cable tube anti move device?
- volkaholic1
2 - as soon as I read it, I realized you are right. Does VW really consider that a separate part from the cylinder tin?
16 - makes sense
55 - good question, it is a small part and not the best picture.
16 - makes sense
- david58
- volkaholic1
Of the things that have not already been covered:
1 - factory fan shroud
2 - aftermarket 36hp style doghouse fan shroud
3 - rubber spacer that goes on the FRONT of the doghouse fan shroud, where the accelerator cable tube passes
4 - rubber gommet that goes on the REAR of the fan shroud, where the accelerator cable tube passes
5 - accelerator cable tube
6, 7 - alt/gen backing plates set
8 - fan
9 - fan mounting hub, washers, nut
11 - plastic spark plug wire holder (3 needed)
18 - thermostat
19- thermostat vertical control rod
20 -thermostat washer and retainer
21- thermostat mounting bracket
24- carb stove pipe for per-heat air
25- carb stove pipe grommet
25 - AGAIN! - early firewall tin
32 - early single port cylinder tin
8 - fan
18 - thermostat
- david58
- david58
Here is a good link with part numbers.
http://www.bus-boys.com/aircoolsystem71.html
- david58
Above images images:
From Max Welton Gallery on The Samba
- volkaholic1
I'll see if I can get a step by step with all the factory parts put together on youtube over the thanksgiving break - I'm feeling motivated, plus the kids think it would be "cool"
- david58
That would be great I'm glad you got kids to help.volkaholic1 wrote:I'll see if I can get a step by step with all the factory parts put together on youtube over the thanksgiving break - I'm feeling motivated, plus the kids think it would be "cool"
