Which Fuel Pump Flange to Use?
Moderator: david58
Jim Ed
Post by Jim Ed » Wed Feb 01, 2017 9:36 am
John C. of aircooled.net says he can get bakelite fuel pump flanges and Cip1.com and CB Performance say they have OEM VW fuel pump flanges.
I bought some of the OEM VW fuel pump flanges and they look like they are made of black plastic.
Which would be better?
http://vwparts.aircooled.net/Fuel-Pump- ... 13-303.htm
https://www2.cip1.com/ProductDetails.as ... -127-303-1
http://www.cbperformance.com/product-p/ ... -303.1.htm
Re: Which Fuel Pump Flange to Use?
Post by Leatherneck » Wed Feb 01, 2017 11:15 am
Bakelite has properties that are resistant to Heat and Chemicals whereas Plastic doesn't hold up as well. If you could get OG I would go that route, if not then the Bakelite but that is just an opinion of mine.
Post by Leatherneck » Tue Feb 07, 2017 12:06 am
What did you end up doing?
