Fuel Pressure
bjtj
Fuel Pressure
Post by bjtj »
Hi all,
I am new to the forum.
Got a carb question.
Have a new 1915 engine with Dual Weber 40’s.
What should the fuel pressure be for a mechanical fuel pump.
My problem is when taking off normal and shifting gears I get a flat spot.
Not sure if to much pressure of not enough fuel supply.
Or do I need bigger jets in the carbs.
Joe
V8Nate
Re: Fuel Pressure
Post by V8Nate »
Sounds more like jetting or a dirty jet to me
Sent from my SM-N950U using Tapatalk
