ray: thanks for another super detailed reply! so, here's the scoop:
they're the GR2 ( KYB 365008 ) for the audi 4000/vw quantum
If you are just trying to (a) get rid of that nose high attitude and (b) at the same time get an increase in hnadling of about 100% or more and (c) get your suspension onto parts that are readily replaceable......there is no reson whatsoever to re-locate the lower spring perch.
that would be yes, yes, and yes...
also, i do understand (finally) that
lowering the perch alone does not effectively lower the car. unfortunately i've already machined the weld off a long time ago so i'll be welding it back on anyway, and that way i can adjust/control any excessive preload. i intend to follow all your recommendations on spring compression, etc.
something i didnt mention is that my existing struts/front end are still in the car as it sits in my driveway waiting for parts for the brakes. the strut parts that i'm working with here are from a different car...and i dont have the old damper cartridge anymore, so i cant assemble it in stock trim (even if the lower perch was still attatched). and the existing, stock struts that are still mounted in the car need to stay put for a while longer until the brakes are done and i've driven it a couple times. i was hoping to be able to just follow your designs and build the whole thing on the bench, then swap it out.
not only is that plan not looking so good anymore (because i really need to perform these measurements you describe), but i'm starting to change my mind about how much i want to lower it... i'm considering going big, even if it handles poorly, just because it looks bitchin'. besides, i can always have the other set be the "sensible" ones...
and tires... hadnt considered that yet...i want to run either 205/60 or 195/50...
so, in short, (
) ive gotten a little ahead of myself. i only have a few of the parts i need for a proper mock up and i'm trying to imagine the finished product.
if you have the time, this post on my blog has better detail:
http://borntodieinthegutter.blogspot.co ... art-1.html
also, would you mind emailing me your stub design and any other materials you have about this? that would be a big help...thanks!
