Rear wheel bearings
Moderator: FJCamper
dustrat
Rear wheel bearings
Post by dustrat » Tue May 23, 2017 1:58 pm
Iv'e got a 73 Ghia with swing axle and I'm going to change rear wheel bearings . Does anyone know the manufactuers part number rather than VW number. :?: I want to get bearings locally from bearing supplier before I start the job.
Robert
Re: Rear wheel bearings
Post by Marc » Wed May 24, 2017 2:36 pm
6306
30x72x19mm "deep-groove" single row open ball bearing.
Other numbers include 394 54069 279, 6306.2RSR, 813-134,306, 306TB, 6306 C3, 6306.C3, 6306-J, P306, 91986
There's also a sealed version that's factory-lubricated which some "slammers" are using since an excessively lowered swingaxle doesn't allow any gear lube to make it up to the bearings...I don't know what the life expectancy of those is, never used 'em myself: https://www.amazon.com/6306-2RS-Bearing ... B002BBI5IK
Post by Marc » Wed May 24, 2017 3:11 pm
Manufacturers' P/Ns which cross to 311 501 283:
Beck/Arnley 051-2378
Repco 212-13507
Lazorlite U81-3109
Repco 212-13505
Beck/Arnley 051-3857
Beck/Arnley 67-2378
NTN TMB306B
NTN 6306
MRC 306C
MRC 306S
NTN 6306UC3
NTN 6306V27
NTN 6306X13*JD
Sealed Power F3306
Koyo 6306
Sealed Power B-306
Perfect Circle 306
Vera 64-00451
Vera 64-00097
New Holland 46805
Mopar Y306
Sierra Marine 15-1128
Meritor 1828A157
Meritor 1828A131
Sierra Marine 15-1101
Rover 556050
Triumph 139737
WABCO R674
Vauxhall 1013378
Vauxhall 1013373
WABCO MP674
Vauxhall 903306
Triumph SP73G
Twin Disc Clutch M2381
WABCO S9954
Vauxhall 6305812
Hyster 43306
Joy 301X22
Joy 321X97
Joy 6B306
Joy 94X306
Joy 90371997
Joy E94AX306
Joy 940025306
Lempco TB3306
Joy 94X1
Yale And Towne 545861
Yamaha 93306-205U1-00
NSK 6306UC3
CARQUEST 306
ITM Autoparts 38-99928
National 306
ACDelco 3306
ACDelco 3306X1270
Nachi 6306
L&S 3306
Borg Warner B306A
American Bearing 3306
Fafnir 306K
Green Ball 3306
Federal CHEV306
Hoover A7065
Hoover 6306
Mcquay-Norris BB6306
Mcquay-Norris BB6306-J
FAG 6306TNH.C3
FAG 903306
FAG 330
FAG 330CD
Federal 1306-2
Hoover 306
Timken 306
FAG 6306
Federal 1306
Ahlberg 6306
ACF 160996
Belarus LLIPO-306
Auto Union H1671
Auto Union R6306
Bucyrus Erie 26137000
Bucyrus Erie Q30
Bucyrus Erie QR200
Bolens 1860613
Auto Union 10300
Auto Union 00625032-40
Bucyrus Erie R1522
Case Tractor A223887
Clark Equipment 743438
Clark Equipment 306
Case Tractor 0955CK1
Clark Equipment 820103-32
Clark Equipment 0078014457
Cummins S16069
Cummins 2699
Clark Equipment 11768
Clark Equipment 006326
Cockshutt MXS535
Cummins S16039
Clark Equipment 301349
Eaton 545861
dustrat
Post by dustrat » Wed May 24, 2017 4:54 pm
Thanks Marc, will get in touch with supplier tomorrow .
Robert
dustrat
Post by dustrat » Thu May 25, 2017 3:06 am
Got onto local bearing supplier and got them at 70% cheaper than buying from classic VW parts outlet. Thanks again Marc
Robert
Post by Marc » Thu May 25, 2017 2:14 pm
Yes, it's a good way to get quality bearings, usually at better prices than the Chinese stuff most VW parts-houses are peddling nowadays. We used to go to a bearing specialty store for most of the bearings used in transmissions and Bus reduction gears, the identical Timken part could be had for less than half of the cost of one with a VW P/N label on it. You're bypassing at least two middlemen and their markups. Unfortunately they didn't stock everything, but the savings on the rest still more than justified the trip.
dustrat
Post by dustrat » Wed May 31, 2017 4:38 pm
Had a bit of a job fitting new bearings . I had a puller that I thought would get bearings out, but no joy. In Haynes manual it shows a make do puller made of 2 3/8 inch x 6inch bolts.It took me a couple of attempts to get made correctly but when done worked perfectly . The bearings that I fitted where FAG 6306 and the ones that came out were DWB 6306 C3 . The DWB bearing had a seal on one side but the replacement bearings should be OK. Thanks again for info Marc.
Robert
