fuel sender info 6 & 12 volt what ohm's
Moderator: doc
damo99
Post by damo99 » Sun Oct 11, 2015 7:36 pm
does anybody know the ohm's for full and empty
on a 6 & 12 volt kombi fuel sender (split and bay).
i have been looking for a few weeks now and only come up with
12 volt beetle at 10 to 65 ohm's
Re: fuel sender info 6 & 12 volt what ohm's
Post by Marc » Sun Oct 11, 2015 9:33 pm
Buses and `Ghias used balance-coil gauges through late `73, when they went to the thermal style similar to what's found in Beetles. Type IIIs all used the balance-coil gauge too.
Both setups are described here (including typical resistance values for the 6V - I dunno what they are for the 12V, but I've known several early Buses which were converted to 12V with no change to sender or gauge and they seemed accurate): http://www.speedyjim.net/htm/fuel_ga.htm
damo99
Post by damo99 » Mon Oct 12, 2015 8:07 pm
thanks for the info
