High RPM: How to Get It & What It Means
Moderator: Tom Notch
TeamEvil
Re: High RPM: How to Get It & What It Means
Post by TeamEvil » Thu Dec 09, 2010 12:09 pm
Even though the engine isn't making power after a certain rpm, if the rpms continue to climb, does that mean that the speed continues to increase as well. Say on a fairly flat roadway?
Always wondered.
Thanks!
Bruce2
Post by Bruce2 » Thu Dec 09, 2010 2:09 pm
TeamEvil wrote:, if the rpms continue to climb, does that mean that the speed continues to increase as well.
As long as the clutch isn't slipping.
FJCamper
Post by FJCamper » Thu Dec 09, 2010 3:08 pm
Hi Teamevil,
The increased rpm's and exhaust noise do quickly reach their own limit once the torque/horsepower limits have been exceeded.
FJC
Bugfuel
Post by Bugfuel » Thu Dec 09, 2010 10:31 pm
depending on gearing, it is often still beneficial for maximum acvceleration to rev past the torque and power peaks, just to get the rpms high enough for the next highest gear to start pulling clean and strong. If you upshift just after the power or torque peak, you will need to use a lot of less powerful time to let the engine reach the peak again in the taller gear.
Fiatdude
Post by Fiatdude » Thu Dec 09, 2010 11:33 pm
unless you have a turbo LOL
fastback
Post by fastback » Fri Dec 10, 2010 3:47 am
in those cases u have to look at the HP curve. to se how much HP drops.and compare to where u end up after a gear change
if it drops faster/lower than than the readings before the peak HP.
u want to be in the RPM area where it makes the highest average HP
WickedWagens
Post by WickedWagens » Sat Jun 24, 2017 12:18 am
What do you change long block wise in a high rpm build?say 7-8k rpm. Bearing clearance, oil pump size, etc?
1968 Ghia Land Speed Car
G/CFALT 106.643 MPH 8/2016
G/CGALT 113.131 MPH 9/2016
G/CBGALT 134.606 MPH 8/2017
G/CBFALT 146.715 MPH 8/2017
G/CBGC 158.242 MPH 9/2017
