Making a header for an odd app
Moderator: Tom Notch
DeathBySnuSnu
Re: Making a header for an odd app
Post by DeathBySnuSnu » Mon May 01, 2017 8:12 pm
Here is the complete rebuild over in Trike Talk Forum.
http://www.triketalk.com/forum/threads/ ... nyone-else
Post by Piledriver » Tue May 02, 2017 4:51 am
Absolutely. Epic. Build.
Y'all should read that thread. Pack a lunch, and napkins for the drool...
So glad you fixed that step in the heads, we spent weeks trying to get the Mofoco guy to understand why the step cut was boneheaded... The only easy fix (simple flycut) results in 42cc chambers, which works great if you need >11:1 CR.
petew
Post by petew » Tue May 02, 2017 6:04 am
Mr Snu Snu, there should be an academy award for that sort of machine work. Very, very impressive. I love your trike even more now. As a Christian and a pastor, I really liked your Calvary frame gussets. :)
DeathBySnuSnu
Post by DeathBySnuSnu » Tue May 02, 2017 6:50 am
The heads ended up at 58cc.
A .050 copper ring
And zero piston to cyl deck
Roy does offer a no step head cut now.
Have you seen the advert on the new casting on claudes buggies 044 heads. Claimes of more cfm with less volume/more velocity across the board. All new molds, clean castings, moved valve centers and short side radius.
DeathBySnuSnu
Post by DeathBySnuSnu » Tue May 02, 2017 6:58 am
No denying.....it is welded solid.
And all that machine work is on top of all the machine work to build it the first time around.
Something that is not in that thread is the trans and inside the trans case. It has nut type splined shafts which dont exactly fit a swing case. Bearings are sleeve adaptered in there. And oil ports/drain backs moved for upside down oiling.
DeathBySnuSnu
Post by DeathBySnuSnu » Fri Sep 29, 2017 9:34 pm
What the header ended up being.
petew
Post by petew » Fri Sep 29, 2017 9:56 pm
Nice. :)
You got it driving yet?
DeathBySnuSnu
Post by DeathBySnuSnu » Fri Sep 29, 2017 10:02 pm
No.
Not yet. Just busy with work and have had some health issues also.
Working on a gas tank.
DeathBySnuSnu
Post by DeathBySnuSnu » Sun Oct 22, 2017 5:39 pm
So it started.
Still working out the kinks.
Lots of tuning to go.
But.
I had the coils backward. Swap 2 wires. No real problem.
The ground for the tps magically disappeared. Gotta find that. So just jumped a ground to the tps.
Cranked right up.
Seemed lean.
Scaled up 20%. Fat now.
Cranks right up and idles.
Has been through several warm up cycles.
It is settling in. Over the hots. Time to adjust valves.
First start up.
Alt belt squealing.
Dead battery.
https://drive.google.com/file/d/0B291Vw ... p=drivesdk
petew
Post by petew » Sun Oct 22, 2017 6:03 pm
Sounds good. The ITBs make it sound... umm, like a motorbike... :lol:
DeathBySnuSnu
Post by DeathBySnuSnu » Sun Oct 22, 2017 6:22 pm
It is deep and throaty sounding in person.
Sound big. Really big.
DeathBySnuSnu
Post by DeathBySnuSnu » Mon Oct 23, 2017 6:39 pm
It has now been run through several warm up cycles.
Things are loosening up and settling in.
Over the first start hots.
Scaled up the fuel tables and have it rich now.
The ford idle air valve is online now and working.
It idles on its own now.
The base timing is checked and was on 10 advanced with no advance command (no spark advance word from computer). That is the way ford intended it.
I reved it one time high enough to hit the cam.
It sounds beefy/chunky like a big block Chevy at idle and down low.
But when the cam comes in it suddenly changes and becomes a big motorcycle sounding engine.
Gonna be wild.
DeathBySnuSnu
Post by DeathBySnuSnu » Sun Feb 25, 2018 9:34 pm
Assembled.
Almost done with the building.
Next is tuning.
petew
Post by petew » Mon Feb 26, 2018 1:13 am
That looks great! I'm not usually a trike fan, but that'll be a lot of fun. :)
Post by Piledriver » Mon Feb 26, 2018 12:07 pm
Looks awesome!
So Pete, if you rolled up at the Oz DMV on something like that trike, would their heads explode? :twisted:
