I'm having trouble even finding terms to search this one.
I'm getting conflicting information so I'm looking for more opinions.
I have a T4 engine in a '73 Bus. I have removed the dead mechanical fuel pump and pushrod, fitted a blanking cover to the hole and am setting up an electric pump.
But I have people telling me that without the pushrod or a "sleeve" in the pump pushrod bore, I will be bleeding oil pressure from a passage. bad. One person said to put the pushrod back in to prevent this. Push rod with no pump would be a disaster. So much for that opinion. Shop that built the longblock said it's a non-issue. "we build them like that all the time". But it wasn't their T4 guy talking.
What say ye?
(BTW, am I in the right forum? I got to this one from a search link...)
Fuel pump pushrod issue with electric pump.
Re: Fuel pump pushrod issue with electric pump.
I say no issue but maybe post in the type4 forum if no one else replys
- sideshow
I just removed pump rod and made a cover plate, from what I could tell it was just splash oiled.
- trbugman
Quick search found this.
The rod isn't needed, but the brass guide needs to stay in.
Here is how I did the search.
2333(103x70) Type 4 DTM MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
