How do you balance between 48 IDA throats on a single, double barrel carb?
I've seen a video of it done on a triple barrel IDA. I'm pretty sure you can do it on an IDF too.
All help appreciated.
How to balance between IDA throats?
Re: How to balance between IDA throats?
The 2 bbl IDA does not have a throttle plate bypass screw, so it is very difficult to match the air flow at idle.
Two ways I have heard of are:
Twist the throttle shaft very slightly to open the slow bbl a bit more at idle.
File a small flat on the edge of the brass throttle plate to allow more air around it at idle.
The second is kinda permanent.
Okay, good info. Thanks.
