Mag T1 case - how big is practical?
Moderator: Tom Notch
petew
Re: Mag T1 case - how big is practical?
Post by petew » Wed Apr 26, 2017 1:30 am
Oh... isn't a dremel much the same?
Bruce2
Post by Bruce2 » Sun Apr 30, 2017 1:47 pm
A dremel is a toy.
This is the type you need:
http://www.ebay.com/itm/MAKITA-GE0600-D ... SwvKtY~OWo
andy198712
Post by andy198712 » Mon Jun 12, 2017 6:48 am
I used a corded drill and a small battery dremel for the bits I couldn't reach as I was on a low budget, takes time but I had that. No doubt a corded die grinder would work better.
I recent thought about using a old wood router I have, same thing in theory but cheap used.... 6mm collet if I recall, can get long shank burrs cheap from China
dragvw2180
Post by dragvw2180 » Sun Apr 01, 2018 11:31 am
For the cost I would send the case out and get it clearanced for a stroker crank if that is they way you decide on. I would think about a low rpm engine that builds torque down low , maybe a 82x90.5 maybe even 88's with a small cam and dual carbs and reasonable compression . Almost any combination will work for awhile , put it on the highway and cruise at 70 for a few hours to see if you made the right decisions .
