Engine oil flush on ACVWs?
Moderator: Tom Notch
Bruce2
Re: Engine oil flush on ACVWs?
Post by Bruce2 » Wed Jun 13, 2018 1:35 am
petew wrote:
Tue Jun 12, 2018 11:54 pm
tomorrow I'm changing the oil. I don't want to change down as low as 10W40.
It's winter! Use some 5W-30.
petew wrote:
Thu Jun 07, 2018 11:53 pm
That's why my engine builder suggested.
When VW designed your engine, they picked the inside diameter of the bearings, and the outside diameter of the crankshaft journals that work with a 30 wt oil. Larger clearances are required when you build an engine to use that 60wt tar. Since it's pretty hard to increase the ID of the bearings, and much easier to grind the journals smaller, it's the crank that will be modified. Do you know if your engine builder ground your crank's journals smaller than VW's spec?
If your crank journals are ground to VW's spec, your engine builder is wrong.
The motor runs really cool. Even on hot days the oil temp in my sump never gets above about 185F.
Why the need to use tar then?
Bruce2
Post by Bruce2 » Wed Jun 13, 2018 1:45 am
Ol'fogasaurus wrote:
Fri Jun 08, 2018 5:58 pm
even on days in the 90° I get 60#s of oil pressure when running off idle.
This is bad.
You know the pressure reading is in the cct between the pump and the bearings. When you get such a high reading, it tells me the oil is unable to get into the bearings. When that happens, it "backs up" causing the high readings.
If you had lower pressure, more oil would be passing through the bearings. That's a good thing, right?
The pressure relief valve dumps all oil pressure in excess of 42psi. When your engine produces pressure that high, it puts a ton of heat into the oil as it squirts out of the relief.
I bet you're using 20W-50?
Post by Ol'fogasaurus » Wed Jun 13, 2018 9:15 am
Bruce, that is not an "at cold idle" pressure but warm oil pressure at normal (for the dunes) driving speeds; that is what "off idle" means. I have had many, many cars in the roughly 50 years of driving and have built many engines both stock and modified. I would agree with you that 60#s at idle is bad especially with a "cold" engine but my engine does run the 10#s of pressure for every 1000 RPMs and I do keep the RPMs even when climbing 100' dunes at under 5K. The additional deep sump also keeps oil starvation away (I lost one engine when oil pressure was lost when exiting the dunes on a very steep face) when working up, down, or when "facing" (driving across the face) a dune.
This engine is at least 10 years old but the run time on it isn't that great. When I built this one I was specific to what I wanted/needed plus the other limitations I also wanted so the cam is a high lift, short duration RV style engine with the RPM limitation of about 5500 and the oiling is full flow. When I got the case back from the machinist they noticed that they forgot to do the "sand seal" so I watch things a bit more than normal.
There are still several long dunes I want to "face" and maybe I will but then... maybe I won't make it that long. I've tried several of them but it seems like people don't look but will change up a dune right in front of someone else.
Bruce2
Post by Bruce2 » Thu Jun 14, 2018 12:32 am
Who said "at cold idle"?
petew
Post by petew » Thu Jun 14, 2018 2:24 am
Thanks for your advice Bruce. I appreciate it.
I talked to all the local guys and they're all using the same oil as I am. So I ended up throwing the same spec oil back in. As to my engine builder, he is the son of a VW trained factory mechanic. He and his father opened their shop in the early 60s and fixed VW and porsche. My motor was one of the last he built before retiring last year. Ie. 55 years of VW specialist work. He's built more ACVW motors (street, race, offroad, drag, etc) than I've had hot dinners. So I'll take his tip on oil spec.
I'm not adverse to trying something thinner in the future, but not 5w30.
Post by Ol'fogasaurus » Thu Jun 14, 2018 11:16 am
Assumption based on your post.
ps2375
Post by ps2375 » Thu Jun 14, 2018 2:57 pm
"Tradition"; the art of making the same mistakes as before, on purpose.
I'll leave it at that.
Post by Ol'fogasaurus » Thu Jun 14, 2018 3:00 pm
:roll: :wink: :lol:
Bruce2
Post by Bruce2 » Tue Jun 19, 2018 7:26 pm
You assumed wrong.
Bruce2
Post by Bruce2 » Tue Jun 19, 2018 7:29 pm
Chicken!
What is it you fear, the 5W, or the -30?
petew
Post by petew » Wed Jun 20, 2018 4:27 pm
The 5W is what I fear... and probably the 30 too. Just feels way to thin.
ps2375
Post by ps2375 » Wed Jun 20, 2018 4:52 pm
Either way, there will probably be more oil flowing between parts and actually cooling as it does so. I too was concerned and even a little skeptical when I first put my ACVW on the road. I went with 10/40 or a 15/40 and am now down to a 5/30 or a 10/30 and I have the same pressures and temps, possibly cooler on longer runs since the oil isn't bypassing the cooler anymore.
