im putting discs all around my bug what master should i use?
- kuleinc
I put a new stock 1973 superbeetle MC in my car, and I put front wheel cylinders on the back, and dual piston calipers on the front, and the pedal goes to an inch above the floor, at this point the front wheels lock up, and at no point do the rear brakes work at all...
Suggestions?
Will this Mercedes Benz mast cylinder help?
Suggestions?
1995 BMW 318ti with M3 Motor (Mine)
1994 BMW 325i Sedan (Hers)
1968 Baywindow Camper (Parts Bus)
1971 Westy Baywindow (EFI project...)
My build thread: viewtopic.php?f=14&t=137593
- kuleinc
no, they are from moore parts...
http://www.mooreparts.com/store/categor ... -4-Lug-VW/
They didn't come with caliper bolts, do you guys think grade 8 bolts will be ok? and by "ok" I mean safe...
- kuleinc
I'm working on a bit of a custom M/C this weekend, its an inch, the stock one is 3/4 inch. My problem is my M/C is WAY too small, and I think this should clear it up. This master cylinder would be an alternative to the pricey Porsche 944 one, that needs an adapter plate anyways.
I'll keep you posted as I get it nearer to completion and try it out in my car. Road test may not happen until early next week though, got some machine work to do...
That kit has a stock Karmann Ghia caliper.kuleinc wrote:no, they are from moore parts...
http://www.mooreparts.com/store/categor ... -4-Lug-VW/.
The problem you have is nothing to do with the size of the MC. There have been literally tens of thousands of cars built with what you have and there are no problems. You can try to cover up the real problem with a big MC, or keep trying to figure out the real problem.
The big problem with using a big MC is that your pedal effort goes way up.
Use bolts with grade 10.9, nothing less.
- Stripped66
- kuleinc
Thats what I thought, and I'm using SAE grade 8 bolts...
As to my pedal problem, is it a bad master then?
- kuleinc
I took the master out last night, no fluid in the boot... Not sure what is letting the pedal go to the floor before the front brakes lockup, the rears never engage, and the handbrake doesn't work at all no matter how tight I make the cables...
- turbobaja
What??kuleinc wrote:I took the master out last night, no fluid in the boot... Not sure what is letting the pedal go to the floor before the front brakes lockup, the rears never engage, and the handbrake doesn't work at all no matter how tight I make the cables...
So the rear brake shoes don't grab the drums even with the park handle being applied? Sounds like there's your problem. Something aint right back there. What's with the front wheel cylinders being installed on the rear brakes you mentioned earlier? I'm not familiar with this type of.....modification.
I'd get those back brakes off and start double checking stuff. Lay the shoes in the drums and see how they match up to the contour of the inside of the drum wear surface. You've got to have something funny going on with those back brakes.
Post some pics of the rear brakes once you've got the drums off and maybe we can figure something out from there.
Karl
DON'T QUIT
DON'T QUIT
- kuleinc
Just so you know, this isn't the first time I've done brakes, drum or otherwise.
The rear brakes were done late at night so maybe I brain farted on hooking the cables up to the arms there or something, but before I started I do know that only one side was working, so the cables may be stretched out...
The shoes are VERY near the drums. Using front W/C's in the back is supposed to help make them work better, but I can put the rear ones back in...
It was mentioned in this thread I think...
- kuleinc
One other thing, the front brakes only work when the pedal is near the floor, and then suddenly lock up, I think the seals inside the master may have flipped over? At any rate the master is out now and I'll exchange it, bleed the new one, put it in, double check under the rear drums, and bleed and see how it goes...
- Stripped66
True, but there is a better than good chance that whoever he got the bolts from may have simply referred to the class 10.9 bolts as grade 8 to otherwise not confuse somebody who may already be having a hard time trying to weigh the differences between US and ISO nomenclatures.Bruce2 wrote:There is no such thing as an SAE grade 8 metric bolt. They are inch only.kuleinc wrote:Thats what I thought, and I'm using SAE grade 8 bolts...
Kuleinc,
If those fasteners are stamped with 8.8 or 88, those are not equivalent to grade 8 bolts; those are the metric equivalent of grade 5.
