vw steering wheel to chevy
weldvair
Post by weldvair »
I bought a new vw steering wheel & since have been thinking of putting a chevy tilt
column in my car.......how can I install a vw steering wheel on a Camaro column?
Don :)
retired mech engr living in central florida
weldvair
Re: vw steering wheel to chevy
Post by weldvair »
I have not received a reply so let me change the question.....has anyone installed
a different steering column in their KG?
Don
weldvair
Post by weldvair »
Well.....if no one has put a GM tilt steering column in a KG I think I will do it.
One could then put a after market wiring harness in their car which would
be a easy way of cleaning up the rats nest w/a E_Z wiring harness.
Don :)
Prtexx
Post by Prtexx »
Don, putting a GM col in anything is pretty easy you might have to shorten one to get the correct length but the tilt addition would be nice. Keep in mind with the EZ wiring harness the front parking lights do not stay on when the headlights are on and will need to be rewired (easy fix).
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
weldvair
Post by weldvair »
Thanks for the reply steve....I am currently trying to find a GM steering column.
Don :)
Prtexx
Post by Prtexx »
Depending on your budget Ididit or Flaming River make a good product (new) or 80's and older
Steve
67 VW roadster
84 Westy
There also some tilt setups w/electric power steering built into the column.
(You probably don't want to buy one new though)
With stockish tires probably overkill.
weldvair
Post by weldvair »
I have been using 69-70 Camaro columns in my street rods, but I think I need a shorter one
for the Ghia........I probably will have to go to a street rod site for help.
The prices have doubled since I built my last one.
Don :(
Prtexx
Post by Prtexx »
Those columns collapse and are easy to shorten if no shifter. I paid 250 for a chrome new one for my 36 but had to do some work on it for it to work correctly
Steve
67 VW roadster
84 Westy
weldvair
Post by weldvair »
I bought a tilt column, shortened it 6" & have it set in place w/wood boxes.
I just bought a new KGPR steering wheel that I can not use now.
The wiring will all be done thru a hole in the trunk top using a ez wiring kit.
