944 arms
Re: 944 arms
do not know about the shock attachment, but the stub shafts are interchangeable.
- SCOTTRODS
Re: 944 arms
Bruce, since there's but 2 options... could you post any info you have on both, for th9ose of us watching and lurking for info?
Re: 944 arms
Damn Scott, you are up early
Re: 944 arms
If it's steel, as far as I know (can tell / have noticed) the 944 & beetle trailing arms are identical. So a beetle stub will fit in a 944 arm and vice versa. Indeed, I did exactly that last week.
Alloy arms have two versions I think (with / without bump stop) but can't confirm the shock mount location. The alloy arms have a completely different bolt pattern where it mounts to the spring plate and also use different bearings so I have a suspicion (not confirmed) that the beetle stubs will not fit. Certainly the later 944 use a different hub nut.
- SCOTTRODS
Re: 944 arms
Thanks Bruce. I have often wondered what the big deal was, but figure now, that the best thing to gain from going 944, is taking the disk Brake assemblies to use, more than the arms, etc... Makes sense now.
Re: 944 arms
Yup,
[img]//images.tapatalk-cdn.com/15/04/10 ... 4e94a4.jpg[/img]
Re: 944 arms
Scott,
If you use both the spring plate, and the arm, a bit of height adjustment/ camber adjustment is available via the eccentric bolt at the joint where they connect.
IIRC it works out to roughly 1.5-2" total adjustment without reindexing the t bars
mainly used for corner weighting
Re: 944 arms
Thanks guys appreciate the replies, I need 4 stud pattern so if Beetle stub axles don't fit I will have to stick to my steel arms. I am trying to shave every little ounce off the back end as possible.
Craig
Craig
