Solex 34 pict 3 without ventury
Moderator: Marc
Shadyabinader
Post by Shadyabinader » Thu Sep 07, 2017 4:31 am
I was thinking of installing a single carburetor solex 34 pict 3 without a ventury tube on a 2 liter type 4 stock engine
has anyone tried this ?
what is the modification of the jets ?
does it work fine ?
Bruce2
Re: Solex 34 pict 3 without ventury
Post by Bruce2 » Fri Sep 08, 2017 1:58 pm
..does it work fine ?
no
Shadyabinader
Post by Shadyabinader » Sat Sep 09, 2017 12:37 am
Any info of this issue i have seen on youtupe alot of videos how they make it work
Marc
Contact:
Post by Marc » Sat Sep 09, 2017 10:47 pm
Not really sure why this is in the Type 1 Forum. NO center-mounted carb on an ACVW is going to have tolerable driveability without manifold heat and appropriately-sized intake runners, small enough to maintain flow velocity - neither of which is present on a Type IV application.
Running a 34PICT-3 venturi-less will gain at best a couple of HP in the upper-RPM range; below that, both HP and torque will suffer. I'm hard-pressed to think of any real-world application where that would be considered advantageous.
Post by Piledriver » Sat Sep 09, 2017 11:14 pm
If you had one on each side it would work better, but just buy Kadrons in that case.
Much easier to get parts/tune.
The venturi-less setups were usually done to get around racing class restrictions, take them as a work around for that rather than as a performance recommendation. They weren't intended to be driven, just used at WOT and high RPM.
A Type4 likes a set of Webers, or port EFI, with the factory EFI manifolds and a modern programmable ECU it can rock.
The same is pretty much true of T1s as well.
