Flashers not working
Moderator: Marc
margie68
Post by margie68 » Thu Sep 06, 2018 2:20 am
I have 2 VWs and 1 (1968) is not indicating right and my other one (1971) went out in sympathy and isn't indicating left. What would be the things to look for first? Thanks
ainokea
Re: Flashers not working
Post by ainokea » Mon Oct 01, 2018 7:46 pm
Fuses and bulbs first.
Post by Chip Birks » Mon Oct 01, 2018 8:57 pm
If indicating one way, and not the other, the problem is either bulbs, or the switch itself, your fuse is fine.
margie68
Post by margie68 » Sat Oct 06, 2018 11:53 pm
Update - one of them that has the right flasher working, the left will work if it is depressed slightly and held there, but won't work when pulled all the way down. Fuses fine and bulbs fine.
Bruce2
Post by Bruce2 » Sun Oct 07, 2018 3:08 am
bad grounds
