1776 engine?
Moderator: Marc
galaxierace
1776 engine?
Post by galaxierace » Thu Jan 02, 2003 11:12 pm
The left side of my engine is stamped vw 211.101.101 D and the right is stamped vw 211.101.102 D. I guess my question is, What does this engine stamp stand for and why is the left stamp# different then the right stamp#? I was told when i bought it that it is a 1776cc is this true?
verbeekb
1776 engine?
Post by verbeekb » Thu Jan 02, 2003 11:46 pm
Hi galaxierace,
You have found the partnumbers for the case-halves. Most probably they are only there as an internal reference for Volkswagen AG as the case halves were only available as a married unit bearing a different partnumber than the ones you have found. The partnumbers are different because the parts are different, a left half and a right half. There is no way of knowing whether or not your motor is a 1776 by just these partnumbers. A custom built 1776 engine could very well be based upon an engine case bearing the numbers you have found.
I hope it helps,
Brian
galaxierace
1776 engine?
Post by galaxierace » Thu Jan 02, 2003 11:54 pm
thanks brian!!
Who is online
Users browsing this forum: No registered users and 1 guest
