480whp 65' Bug k20 turbo, New BOR 67 incar video!!!!
capsoval
Re: 480whp 65' Bug k20 turbo, New BOR 67 incar video!!!!
Post by capsoval » Fri Mar 29, 2013 5:06 pm
badbull21 wrote:930 Box should fit with little mods.
Yes, the 930, or G50 would be easier to fit. But the gearing is too tall for my liking. Not to mention become more and more difficult to find at reasonable prices. And would still require a lot of modifications to make work the way I want it too. If everything go well, the G96 should be a damn near perfect gearbox for my application, and easy to locate and inexpensive to replace. I picked up mine with 30,000 miles on factory rebuild for 1800. Can with slave, pressure plate, a used disk and dual mass flywheel. Bought a 911tt shifter for 60$ on eBay and Boxster shift cables for 45$ on eBay. Gear box is rated by Getrag at 480ftlbs in a 4,500lb car.
Gear spacing for my tires and shift points
1- 51mph
2- 89 mph
3- 129 mph
4- 160 mph
5- 192 mph
6- 233 mph
Obviously 5 and 6 are not practical for 1/4 mile, but if I ever decide to do a standing mile 5th will get used. And crusing will be amazing.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
supaninja
Post by supaninja » Fri Mar 29, 2013 9:04 pm
that ratio will be nice and tall, sweet!
viewtopic.php?f=14&t=140387
capsoval
Post by capsoval » Fri Mar 29, 2013 9:35 pm
supaninja wrote:that ratio will be nice and tall, sweet!
Yeah, it seems tall, but its really not all that bad. My previous 002 bus box was as follows:
1- 42mph
2- 72mph
3- 110mph
4- 156mph
All mph are based on an 8700rpm shift point.
capsoval
Post by capsoval » Fri Mar 29, 2013 9:39 pm
A standard NA G50 5- speed would be:
1- 56mph
2- 95mph
3- 138mph
4- 173mph
5- 220mph
1-4 spacing is just to long.....and a 930 turbo box would be so much worse.
Jadewombat
Post by Jadewombat » Wed Apr 10, 2013 4:31 pm
Cool stuff, but I doubt you'd get over 130mph. The car would flip a long time before then.
http://www.youtube.com/watch?v=g8XxQkXCmsU
capsoval
Post by capsoval » Wed Apr 10, 2013 5:10 pm
Jadewombat wrote:Cool stuff, but I doubt you'd get over 130mph. The car would flip a long time before then.
I actually have already trapped over 133mph in the 1/4 mile with the 480whp motor. New motor should make near 700whp.
capsoval
Post by capsoval » Tue Apr 10, 2018 6:23 pm
So sad to think this build had been dead for 6 years.
volkdent
Post by volkdent » Tue Apr 10, 2018 8:07 pm
That's how it goes!!! Hoping to have the bug back on the road this fall after after a new motor build and powdercoating the subframe.
Post by Chip Birks » Tue Apr 10, 2018 8:17 pm
Welcome back! So did you sell the car then?
capsoval
Post by capsoval » Wed Apr 11, 2018 10:31 am
What did you find wrong with it? Glad you’ll be having it back together soon.
capsoval
Post by capsoval » Wed Apr 11, 2018 10:35 am
No, didn’t sell it. Just no progress on it. I’ve had it in my mind that I’ve known exactly what it needed to be reliable and still make the power I wanted it to, but I couldn’t find a machinest to make a part I needed.
capsoval
Post by capsoval » Wed Apr 11, 2018 10:37 am
What is everyone using these days for photo hosting, a lot has changed in 6 years, lol. I see sooooo many broken links thanks to webshots greed.
volkdent
Post by volkdent » Wed Apr 11, 2018 12:31 pm
I used the Samba a lot before I stopped posting, and those pics are still there.
I think I have a valvetrain issue with one cylinder, I'll find out when I pull the motor. Just ended up with suspected broken main caps in my 2JZ swapped E46 Touring, so I'm focusing on getting that thing back before I crack in to the Bug.
capsoval
Post by capsoval » Wed Apr 11, 2018 1:51 pm
Really? Broken main caps? How much damage total? Crank and rods okay? What power level was it at when it broke cause I no it’s not always on “kill”....or is it?
capsoval
Post by capsoval » Wed Apr 11, 2018 7:15 pm
Test
