480whp 65' Bug k20 turbo, New BOR 67 incar video!!!!
volkdent
Re: 480whp 65' Bug k20 turbo, New BOR 67 incar video!!!!
Post by volkdent » Wed Apr 11, 2018 7:24 pm
capsoval wrote:
Wed Apr 11, 2018 1:51 pm
volkdent wrote:
Wed Apr 11, 2018 12:31 pm
I used the Samba a lot before I stopped posting, and those pics are still there.
I think I have a valvetrain issue with one cylinder, I'll find out when I pull the motor. Just ended up with suspected broken main caps in my 2JZ swapped E46 Touring, so I'm focusing on getting that thing back before I crack in to the Bug.
Really? Broken main caps? How much damage total? Crank and rods okay? What power level was it at when it broke cause I no it’s not always on “kill”....or is it?
Yeah, I've got 4 boost settings currently, but I should have done billet mains. The builder planned on 1000hp, but didn't really plan on just how much torque my turbo created. It's a GTX3584RS, and we ended up with 924whp, but it probably makes over 800ft/lbs of torque. There was also an issue with the WG being too small for how efficient the turbo is. Ended up with boost creep, and on a very cold night with pump gas I might have overboosted and had detonation that was part of the problem. Hoping the rest of the engine is just fine, just machine in the billet mains and re-assemble and chuck it back in.
Jason
panel
Post by panel » Thu Apr 12, 2018 9:10 pm
capsoval wrote:
Wed Apr 11, 2018 10:35 am
, but I couldn’t find a machinist to make a part I needed.
What were you needing done? (no I'm not a machinist :) )
Subaru JDM EJ20 Turbo bus
capsoval
Post by capsoval » Thu Apr 12, 2018 11:52 pm
An adapter plate to bolt the k series to a Porsche 996 gearbox.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
maurice
Post by maurice » Tue May 22, 2018 12:05 pm
I might be able to talk my neighbor into making one... I assume you're local to Northern California?
