DIY - 1990-1994 1/2 EJ22 Subaru Conversion with stock ECU
TimS
Re: DIY - 1990-1994 1/2 EJ22 Subaru Conversion with stock EC
Post by TimS » Fri Jul 17, 2015 1:32 am
You are welcome, Ed. Yellow red doesn't sound like a speciality wire it sounds like an "ignition on" wire. I may have got that wrong. Glad your running.
Snowcat Operations
Post by Snowcat Operations » Thu Jul 23, 2015 4:37 pm
I joined this Forum just because of this thread. Thank You very much for taking the time and considerable effort into addressing the issues involved as well as the How To aspect of this engine swap. I am looking at a used Subaru today to purchase. I will start my own thread with tribute to you. Thank you again.
Mike
ezytroopy
Post by ezytroopy » Thu Aug 27, 2015 9:06 pm
Joined the forum due to reading this post. I am starting a EJ22 conversion from a 93 Liberty into our 69 Kombi. Both the engines are out and adapter kit is on its way. The best reference material i have found on the wiring conversion. Great job and Thanks.
TimS
Post by TimS » Fri Sep 04, 2015 4:48 pm
Thanks. Please don't forget to support ShopTalkForums and Doc for hosting this information for you. This site is supported by user's donations and even a few dollar donation every now and again will help keep this forum advertisement free (except for those pesky signature ads... :evil: ) and will keep this information available for future users.
ezytroopy
Post by ezytroopy » Sat Sep 05, 2015 2:08 am
I checked the ECU plugs today and there wire colour is different to what you have. I then downloaded the Subaru wiring, It was alittle different to yours and to mine as well? I pulled the harness out in one piece. I will over the next few days(weeks lol) start checking the wires from my ECU to the sensor plugs and rewrite what you have done. The Australian 92 Liberty wiring must be alittle different to the overseas variant. I will post it up when sorted if you think it might help somebody else. Cheers
TimS
Post by TimS » Sat Sep 05, 2015 6:27 am
I think nilza, a couple pages back, did an Australian conversion and outlined the differences. Yes, this is based on usdm cars. I would happily add an Australian supplement if you'd like to put something together.
joelzy
Post by joelzy » Fri Sep 11, 2015 4:25 pm
Hey everyone, noob here swapping a 95 EJ18 into my 69 standard beetle.
Been doing a lot of research and i must say that this is hands-down the best source i've found so far and what will probably become my saving grace while tackling the wiring portion.
Thank you TimS!
ezytroopy
Post by ezytroopy » Sat Sep 12, 2015 4:10 am
Hey, quick question, how do you rejoin the grey shields once cut? Cheers
TimS
Post by TimS » Sun Sep 13, 2015 10:15 pm
ezytroopy wrote:Hey, quick question, how do you rejoin the grey shields once cut? Cheers
Crimp. They are aluminum, I think, and I couldn't get them to solder.
ezytroopy
Post by ezytroopy » Tue Sep 15, 2015 6:03 pm
Yep, your 100% right TimS . Cheers mate.
TimS
Post by TimS » Thu Sep 24, 2015 1:12 pm
After many years of using the automatic beetle starter, I just put in a starter from a 2001 jetta tdi. Works great.
D2NE
Post by D2NE » Thu Sep 24, 2015 7:42 pm
Tim,
Did you have to do anything to the holes on the starter to make it fit?
TimS
Post by TimS » Thu Sep 24, 2015 8:32 pm
Yes. You can get away with ovaling out one hole, but I modified both holes a bit to keep as much meat on the engine mounting stud. I just used a dremel and a raspy-thingy used to cut tile.
ezytroopy
Post by ezytroopy » Thu Oct 22, 2015 5:50 pm
Can you use the subi stater motor?
Prtexx
Post by Prtexx » Fri Oct 23, 2015 10:43 am
Only on a buss if you use the aftermarket bellhousing with hyd clutch.
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
