56' Vdub-aru...VW,Mendeola,Subaru,Porsche,BMW..the works!
56SemaRag
Re: 56' Vdub-aru...VW,Mendeola,Subaru,Porsche,BMW..the works
Post by 56SemaRag » Mon Feb 25, 2013 12:43 pm
ambrynmc wrote: That is a nice little bit, where did you find it?
My Race Shop
I have a bit of other stuff to do on the car so I will kick the clutch can down the road until you figure out which one is going to work best :lol:
56' Semaphore Ragtop Subaru (Build)
Subaru Engine & Transmission
Mendeola Suspension
69' Karmann Convertible (Build)
Suby AWD Driveline
05 Suby Baja Turbo - Stage 2+
07 Legacy Spec B - Stage 2
15 Suby Forester XT
coolrydes
Post by coolrydes » Fri Mar 01, 2013 12:25 pm
My Race Shop
Sweet, those guys are sponcered by Mendeola Transaxles. Small world
Kevin "Coolrydes" Zagar
MENDEOLA SIGNATURE MOTORS
56SemaRag
Post by 56SemaRag » Sun Mar 10, 2013 4:04 pm
Got to work on the car a bit today. Gave the Subamount a try and for my car it came up a little short on the upper bolt holes. The lower engine/transmission bolt section of the housing is making contact with the transmission horns. I want to utilize the upper mounting holes so I can run DOHC if want to. The angles were slightly off where the engine mounts hit the banana horns of the Subamount, tightening them will compress the outboard part of the mount and expand the inboard side. Not a very big deal but since I have to work for clearance might as well fix it. I may do what I had to do with the kafer plates. Slice, reposition and weld em up
Contact, mounts not resting on Subamount
Left side engine contact
Left side engine mount deflection
Right side engine contact
Right side engine mount deflection
Going to work on this during the week. Any suggestions before I begin the operation let me know what's on your mind. Thanks gents.
Mendeola Suspension
Suby AWD Driveline
15 Suby Forester XT
ttriebler
Post by ttriebler » Sun Mar 10, 2013 4:57 pm
Strange that the angles are off. Looks like you are using the composite liquid filled mounts too.
What are the part numbers on your mounts?
56SemaRag
Post by 56SemaRag » Sun Mar 10, 2013 6:07 pm
Not really a big deal. Might have to do with mine being an early pan. Have run into a few issues, but putting big motors into early VW's has always been challenging. These mounts do fit better than the Type N's that I used in comparison.
Mendeola Suspension
Suby AWD Driveline
15 Suby Forester XT
ttriebler
Post by ttriebler » Mon Mar 11, 2013 3:34 pm
Yes...custom cars always require a little massaging.
You definately have the correct part numbers there.
Fair point about the pan - I developed the angles for the mount using an IRS pan and got everything to line up nicely. Perhaps there is some slight difference with your setup.
vwrxbug
Post by vwrxbug » Mon Mar 11, 2013 8:56 pm
coolrydes wrote:
My Race Shop
I want to be sponsored by Mendeola Transaxles! LoL :P
56SemaRag
Post by 56SemaRag » Fri Mar 15, 2013 1:30 am
Cut enough of the mounting tabs to bend them into position. Surprisingly they needed to be 90 degrees which made it easy. The angle was spot to the bottom plate of the composite mount, but still a bit low to my liking so I temporarily put in some 1/4 shim plate an got the clearance. Now I can order some axles finally.
Mendeola Suspension
Suby AWD Driveline
15 Suby Forester XT
coolrydes
Post by coolrydes » Sat Mar 16, 2013 12:47 am
Here is how we do it.....
56SemaRag
Post by 56SemaRag » Tue Mar 19, 2013 1:29 pm
Hey Todd,
For the guys running the extended Subaflanges what are you guys using to seal off the inward creep of the CV grease and keeping out contaminants from the unused roll pin holes? I figured there is a cap of some kind for the splines and fill the roll pin holes with a dap of sealant. Let me know your thoughts.
Mendeola Suspension
Suby AWD Driveline
15 Suby Forester XT
vwrxbug
Post by vwrxbug » Tue Mar 19, 2013 8:07 pm
coolrydes wrote:Here is how we do it.....
I want, I want!! LoL
coolrydes
Post by coolrydes » Thu Mar 21, 2013 12:21 am
Another one coming soon....
coolrydes
Post by coolrydes » Fri Apr 12, 2013 12:00 am
Here is a full kit that allows a Subaru to go into a type one with out much trouble....
jokswgn
Post by jokswgn » Fri Apr 12, 2013 7:42 am
Whats the cost for the mounting kit?.
coolrydes
Post by coolrydes » Mon Apr 15, 2013 6:51 pm
Here is a link to the kits.... Thanks for the inquiry
http://www.thesamba.com/vw/classifieds/ ... id=1460311
