bay windows subi conversion
navarido
Re: bay windows subi conversion
Post by navarido »
this evening i have place the order at PACIFIC CUSTOM!
8) 8)
ORDER THE KENNEDY ADAPTER KIT
http://www.pacificcustoms.com/mm5/merch ... ange_high=
THE KENNEDY STAGE 1 200mm CLUTCH KIT
AND THE KENNEDY PILOT BEARING FOR SUBARU AND ECOTEC ENGINE ADAPTER FLYWHEELS
NEXT WEEK I DESMOUNT THE ENGINE TO THE SUBARU! 8) 8) :mrgreen:
navarido
Post by navarido »
today i was receved the wirig instruction to the kep! 8)
but i was discovered the first little problem.... :|
navarido
Post by navarido »
a big box at home today! :mrgreen: :mrgreen:
navarido
Post by navarido »
:lol: :lol: 8)
good neewss!!
today i start to remove the engine to the subaru
navarido
Post by navarido »
i have found this yellow box.....
what is this??? :shock:
Steve Arndt
Post by Steve Arndt »
SRS stands for supplemental restraint system usually. Perhaps it is an air bag sensor.
Prtexx
Post by Prtexx »
I believe everything with the bright yellow is for the airbag system.
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
navarido
Post by navarido »
engine out! :mrgreen:
navarido
Post by navarido »
:shock: :shock: :shock: wiring hell!! :shock: :shock:
many cablesss!!
and
WHERE IS THE ECU!!??? :shock: :shock:
Prtexx
Post by Prtexx »
Under the front passenger side carpet.
Steve
67 VW roadster
84 Westy
ajdenette
Post by ajdenette »
Pulling the harness will be easier if you pull the crash bar (the large bare steel welded bar running from the Drivers side to the passenger side A pillars) then pull the large Heater box and you will see all the bulkhead wiring that you need to pull.
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
navarido
Post by navarido »
Prtexx wrote:Under the front passenger side carpet.
lovely! :mrgreen: :mrgreen:
Superalf72
Post by Superalf72 »
go nava gooooooo
navarido
Post by navarido »
hallo friends!
this is the moment!
i have removed the total of wiring haness
this is how i can find!
i don't find the OBDII CONNECTOR!
you can help me ??
:shock:
Prtexx
Post by Prtexx »
Good morning (at least here) the OBDII is located just left of the steering col and can be black or white. You can see it on the lower part of the dash.
Steve
67 VW roadster
84 Westy
