oops! Tried to copy and paste picture of the relay diagram but no go, so will try to explain in my convoluted way.
I have power coming back through my switch on line everything checks out as far as the schematic goes but the double ignition relay, I assumed there, it shows one side powered and grounded but I figured if working in tandem they would both need to be so I wired them as such, is this where the power is feeding back?
if just connecting the battery there is no power all is good connect the switch on relays click and there is power, can pull it and engine will quit but switch on line still has power the ecu blinking its little green eye at me telling o2 sensor problems (not hooked up).
The diode is in the right order leg color and arrow.
Will keep digging but was wondering if you had encountered this? Thanks
W.C.(Curt) Acree
