My '74 2.0 Restoration introduction... Dyno results!
Moderator: Piledriver
Re: My '74 2.0 Restoration introduction...
Post by Piledriver » Fri Jan 02, 2015 4:20 pm
Nice!
What TBs did you go with?
falcor
Post by falcor » Sat Jan 03, 2015 1:33 am
I got the 40 mm ones from vwspeedshop, same ones as Mario sells.
aircooledtechguy
Post by aircooledtechguy » Mon Jan 05, 2015 10:28 am
Looking very, very nice. I have the same ITBs on the Squarsche; you'll love them!! What EFI will you be running??
falcor
Post by falcor » Mon Jan 05, 2015 3:30 pm
I'll be running the swedish designed MaxxEcu, mainly because its swedish made and has some cool features like full E85 support with real time detection of fuel mixture and two temperature input ports that can be used for sensors under the sparkplugs. Its also got bluetooth that can send data realtime to an android tablet and show whatever data you want in the cabin. For starters I'll just be running it on petrol tho untill I can increase the volume and bump the CR to take full advantage of the E85.
falcor
Post by falcor » Sat Mar 14, 2015 3:44 pm
Rear brakes and hardlines mounted
Engine decklid painted (the black pieces) and mesh grille installed with new rubber lining.
Lower and upper front targa seal installed.
Glued the top vinyl in aswell.
Post by Piledriver » Sun Mar 15, 2015 12:06 am
Looking good, sir.
aircooledtechguy
Post by aircooledtechguy » Tue Mar 17, 2015 8:22 am
Your car is coming along very nicely. Keep up the good work!!
falcor
Post by falcor » Sat Apr 04, 2015 11:46 am
Thanks Pile and Nate. :)
This easter weekend will hopefully see me getting all the engine tins and some other parts powdercoated, then once I get a trigger wheel setup and a thermostat I can start assembling the longblock to a complete engine and get it and the gearbox back into the car.
The Newf
Post by The Newf » Sat Apr 04, 2015 12:01 pm
Nice work sir.
falcor
Post by falcor » Wed Jun 03, 2015 4:01 am
Current status... :D
aircooledtechguy
Post by aircooledtechguy » Wed Jun 03, 2015 9:11 pm
I love the Martini livery!! My personal favorite.
falcor
Post by falcor » Fri Jul 03, 2015 2:00 am
Last week saw the Engine jump into Place with the usual 914 Engine tin interference issues....
Struggling a bit with getting the TBs to close properly after a few pushes to the pedal. Have tried a harder pulling return spring but the issue seems to be in the pedal or old throttle wire....new wire ordered.
falcor
Post by falcor » Fri Jul 10, 2015 6:25 am
falcor
Post by falcor » Sun Jul 12, 2015 1:01 am
Its on the ground!
falcor
Post by falcor » Sat Dec 26, 2015 12:06 pm
Houston, we have cranking rpm... :D
Got some work done today. Pulled the intakes off, removed the plugs and checked the plug gaps. All good. Proceeded to mount the oil filter, fill the engine with oil.
Then I built a remote start switch and hooked it up. *drumroll* It cranks! :)
http://matsgarage.com/wp-content/upload ... rigger.jpg
http://matsgarage.com/wp-content/upload ... nk-osc.jpg
