Front rotor grease seals
Moderator: Piledriver
Post by Piledriver » Tue Feb 16, 2016 3:38 am
The big FLAPS chains (Oreallys/autozone) link a #1217 front wheel grease seal for late T3s and 914s.
(right along with the early seals that don't fit at all)
This is also the same seal on the early 914, the late T3 uses the early 914 (411) rotors.
That is a single lip seal and IME does not last long.
The OEM part# crosses to a #1962 seal, which is a flanged double lip seal unit and it is just as common and costs no more.
Works peachy.
Spooge some grease in the groove between the lips before installing.
Re: Front rotor grease seals
Post by raygreenwood » Tue Feb 23, 2016 9:33 am
Thanks Piledriver. I have also found Rockauto sellling Sabo front rotor seals in this part # for about, $2 each at times.
