'76 914 2.0 engine build advice
Posted: Tue May 02, 2017 7:09 pm
Hey everyone,
I'm currently rebuilding the engine on a 1976 914 2.0. It has the original detuned GC coded engine that came with California emissions D-jet, air pump and catalytic converter.
My goal is to keep the engine fairly original while doing any worthwhile upgrades in the process. I would like to keep the D-jet fuel injection if possible but I don't mind ditching the air pump and cat as I don't live in a state that has strict emissions laws.
Here is what I am thinking so far:
-Reconditioned Stock 2.0 heads (New valves, new guides, cut seats, CC matched chambers, spark plug inserts).
-Stock 71mm crankshaft w/Stock connecting rods.
-96mm P/C set from Aircooled.net (Cast Piston & Biral Cylinder Set, 96mm x 71mm) Has anyone used these? Are they any good for the $360 price?
-Raby 9590 Cam Kit.
I'm guessing that the original detuned california D-jet setup is going to be useless with the big bore pistons/upgraded cam profile, is this correct? If so can I retrofit the computer from a U.S. 1973 spec/ROW/euro spec computer with my system? How much of the cali emissions 75-76 F.I. components jive with the earlier systems? I'm already planning to buy a new D-jet wiring harness and I don't mind tuning a system to work properly (as close to "properly" as I can get with a 41 year old analog computer running an engine it wasn't designed to run)
Any advice is appreciated and thanks in advance!
-Raby 9590 Cam Kit.
