Weld-in fuel injector holders
- CBDZ
- sideshow
Here is a picture from the UAC thread
http://ultimateaircooled.com/simplemach ... c=2132.285 one of the drag racers is installing a set of the second generation injector holders for the Red Baron. At the same time the car is going back to gas from alcohol and the intake is being reworked.
The price of the injector holders is currently 40$ each and have more material on the manifold end.
- notched
I believe that Ethan has these in stock now. Email him at [email protected] and he can send you an invoice.
With plumbing...
With plumbing...
- JSL56
Re: Weld-in fuel injector holders
Hi,notched wrote:Weld-in fuel injector holders available soon from Doubleday Racing...
Featuring AN (JIC) -6 male fitting incorporated into the aluminum tops and stainless steel hex-head screws. Available in steel or aluminum bottoms. You can create your own fuel injection system with much more flexibility.
http://www.doubledayracing.com [site under construction, but will be up soon]
A good friend of mine is making these, thought you guys might be interested. Let me know if you have any questions!
Phillip
Anyone know if these are still available? I tried emailing Ethan but havent heard back yet?
Cheers,
J
- Alexander_Monday
Ditto. Ethan did return 1 email several weeks ago. but has not replied to my latest. I was curious if I could get them with steel top and aluminum body. It took several attempts the first time.
