CLT placement
Moderator: Tom Notch
Steve Arndt
Re: CLT placement
Post by Steve Arndt » Sun Jun 24, 2012 8:53 pm
I wish it was complicated..... Those were the days.
I have 9 thermocouples on my engines as we speak. I don't have one for warmup / coolant enrichment, which was the point of this 4 page thread.
Steve Arndt
Re: CLT placement
Post by Steve Arndt » Sun Jun 24, 2012 8:55 pm
MarioVelotta wrote:Image
I will use the most accurate sensors I can afford regardless if the OEM's use them or not. This is my motor not theirs. The motors they test in the R&D Dyno room are TC'ed up the yang. My motor is a one off so I consider it R&D, it needs to be monitored the best I can afford.
Remember we are talking warmup / "over heat" enrichment here.
Jadewombat
Re: CLT placement
Post by Jadewombat » Thu Jul 05, 2012 3:40 pm
I'm new to doing full-MS, is there any reason you can't use the stock VW temp II sensor or does it have to be the GM type one?
Paul H
Re: CLT placement
Post by Paul H » Wed Jul 11, 2012 2:42 pm
You can program in the temp curve on any regular temp sensor, I use boiling water , a bag of frozen peas and a thermocouple thermometer to do this .If you are talking about the Mexican head temp then yes you can use that too
Paul H
Re: CLT placement
Post by Paul H » Mon Aug 13, 2012 1:13 pm
Here's our new temp sensor
M6 thread 8mm hex stainless -40 to 250C thats -40 to 482F
Sensor tip is actually down the thread a couple of mm so offset will be negliglable
panel
Re: CLT placement
Post by panel » Tue Aug 14, 2012 6:48 pm
That's clean and neat!
Subaru JDM EJ20 Turbo bus
UKLuke72
Re: CLT placement
Post by UKLuke72 » Fri Dec 08, 2017 5:37 pm
Any details on these Paul... Still selling them?
Paul H
Re: CLT placement
Post by Paul H » Sat Dec 09, 2017 4:15 am
Normally just supply them with kits and at £35 they're a bit pricey
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
UKLuke72
Re: CLT placement
Post by UKLuke72 » Sat Dec 09, 2017 9:38 am
Fair, cheers for the reply :)
