MS-3 2110 Buildup
Moderator: Tom Notch
Max Welton
MS-3 2110 Buildup
Post by Max Welton » Fri Feb 03, 2012 12:34 pm
So I'm rebuilding my Karmann Ghia. Back when it was my daily-driver, it just had a 1600 Kadron engine. Worked just fine.
But I recently converted my type-3 to Megasquirt and it worked out so well, I figured I could apply what I learned to building the new engine for the KG.
http://www.maxwelton2k.net/squareback68/MST3/
The engine this time will be a standard 90.5-over-82 2110 built on a virgin as21 case a friend brought back from Pomona.
This will be my build thread, mainly concerned with the FI and Ignition control systems.
This is the subject, a 67 KG coupe:
Max
Max Welton
Re: MS-3 2110 Buildup
Post by Max Welton » Fri Feb 03, 2012 1:10 pm
First the goals.
I want this engine to make good torque from 1-5k RPMs. My preferred driving technique is to shift-short and keep the revs low. I actually prefer an engine that pulls hard to 5k and no more. I will be making cam and valve train choices to encourage that behavior.
I could certainly do this with carbs and a distributor. But that would be boring. :lol:
What I plan is to control both fuel and ignition with MS. I would also like to get rid of the distributor, going either with a Coil On Plug (COP) or Coil Near Plug (CNP) and crank-trigger approach.
What I already have is as follows:
From the previous project I have the LC-1 WB system and TunerStudio all loaded up on my old laptop.
I have now purchased from an assembled MS-III w/pre-installed MS3X Expander Board ( http://www.diyautotune.com/catalog/mega ... p-476.html ) ,
their complete wiring harness ( http://www.diyautotune.com/catalog/1239 ... -p-43.html ) and MS Relay and power board ( http://www.diyautotune.com/catalog/mega ... -p-32.html )
For an intake system, I have acquired the Throttle Bodies from an 1999 Honda Interceptor VFR800, alleged to be 37mm.
So this setup already has the TPS, FPR, injectors and the fuel rail. These are all things I had to buy or make for my squareback project. I also see what appears to be a set of valves for idle control.
Max
Max Welton
Post by Max Welton » Fri Feb 03, 2012 1:45 pm
Bore centers on these TBs is right at 92mm. I've read that is very close to the spacing on IDF manifolds, but I don't have any to measure.
The bore at the bottom is just over 36mm.
Max
Dale M.
Post by Dale M. » Fri Feb 03, 2012 2:33 pm
IDF's are 90mm C to C ..... Simple adapter plate and fudge factor the 2 mm with the 37mm barrels should not be a problem....
Dale
Max Welton
Post by Max Welton » Fri Feb 03, 2012 5:15 pm
Yep, sounds right.
Since it's a Ghia, I need to be careful about how tall things get. The KG engine room is wide, but short.
The TBs themselves are about 3" tall and I still need to think up some sort of air-filter arrangement.
Another thing to consider with manifold selection is whether they will interfere with whatever I use for COPs.
I've been thinking about type-3 style IDF manifolds like these, but perhaps I should select some COPs first.
http://www.thesamba.com/vw/classifieds/ ... id=1194719
What is out there for CNPs that would still give me one coil per plug?
Max
supaninja
Post by supaninja » Fri Feb 03, 2012 7:08 pm
That 2mm can easily be sucked up by rubber spigot flanges. Looks like a awesome build!
viewtopic.php?f=14&t=140387
Max Welton
Post by Max Welton » Fri Feb 03, 2012 9:18 pm
That what I'm hoping. Thanks Nick.
I'm having some problems doping out what the ignition options are. DYI has this coil-pack that I could locate in front of the engine (out of sight), but it says it doesn't have a built in ignitor. If the coil-pack is basically four small coils, what is the ignitor?
http://www.diyautotune.com/catalog/ign4 ... p-409.html
Do I need something like this to go with it?
http://www.diyautotune.com/catalog/quad ... p-481.html
Max
supaninja
Post by supaninja » Fri Feb 03, 2012 11:42 pm
The IGN-1 will need one BIP373 per coil, if you go with the IGN4 you only need 2 BIPs. Ignitor is just another name for coil driver.
Max Welton
Post by Max Welton » Sat Feb 04, 2012 12:17 am
So in a stock ignition, the points serve as the coil driver?
Max
supaninja
Post by supaninja » Sat Feb 04, 2012 12:40 am
nope- the condenser is more of the "coil driver" and the points would be trigger wheel/vr sensor.
The ignitor/coil driver is what charges the coil. The coil takes the high current from the coil driver and converts it to high voltage.
this is a interesting read http://en.wikipedia.org/wiki/Ignition_system
blue77bay
Post by blue77bay » Mon Feb 06, 2012 1:39 am
Max Welton wrote:That what I'm hoping. Thanks Nick.
Max
Max have a look at these http://www.diyautotune.com/catalog/ign1 ... p-394.html
built in ignitor and fired from 5v logic so no bip's and 1 per cylinder ~~less complications,, however there must be ,i am sure ,some that can be had at a pick n pull for peanuts and i am certain that Mario or somebody here has found a compact COP from a late model ? that clears our manifolds and has the req'd built in ignitor. Good luck i am doing something similar for a daily for my wife's 61 soon.
Max Welton
Post by Max Welton » Mon Feb 06, 2012 9:37 am
That's what I'm looking for.
Can someone point out a late model application I might find in a salvage yard?
Max
Dale M.
Post by Dale M. » Mon Feb 06, 2012 10:45 am
Late Chrysler V-8. (Dodge Ram) ...
Dale
Passatman
Post by Passatman » Tue Feb 21, 2012 8:31 pm
Ls2 truck coils i understand are logic level coils they only need the 5v signal to the coil to fire the ignitor is unboard. I think the yukon denali carriers these coils.
Post by Piledriver » Tue Feb 21, 2012 8:39 pm
LS2 coils are cake to work with, logic controlled, integrated drivers and self protecting to at least some extent.
Keeps the noise mostly out of the MS.
The std LS2 coils are very "hot" coils... Truck coils even moreso.
