MS-3 2110 Buildup
- Max Welton
Re: MS-3 2110 Buildup
I just did a little google for "fuel sump" and found this. It's designed to be welded to the bottom of the tank.
http://www.summitracing.com/parts/CEE-4041/
Max
Max
VW makes a nice fuel sump for the Fox and some later cars...
- Max Welton
That might be past tense if it's this one:
http://busdepot.com/details.jsp?partnumber=533201511A
Max
Max
Loads of them in junkyards if they actually discontinued them
That page says "fuel filter" but it really is more of a swirl pot, right?
Search is my friend:
http://www.shoptalkforums.com/viewtopic ... 7&start=90
Steve
Steve
Max Welton wrote:That might be past tense if it's this one:
Max
Steve
My Baja Build
My Baja Build
- Max Welton
Already been there Steve. That thread is how I knew to look for that particular part. What I'm saying is that those sites I found that list it, show it as out of stock. When I tried to order it from busdepot, they told me it was out of stock and they had no idea when it would be available again.
So now I'm looking at alternatives I can either make, buy or adapt. All it has to do is protect me against getting air in the system. Shouldn't be rocket science.
Max
Max
- supaninja
In the meantime Max, just keep over a 1/4 tank of fuel in there and you will be fine.
viewtopic.php?f=14&t=140387
- Dale M.
But its designed for a drag race car and to be put at rear of tank so on acceleration the fuel moves backward into lower part of tank.... Not necessarily a good design for daily driver...Max Welton wrote:I just did a little google for "fuel sump" and found this. It's designed to be welded to the bottom of the tank.
Max
Just go to hardware store or plumbing warehouse and get a piece of copper waste drain pipe 6-8 inches long a couple of "caps" and a few brass fittings and solder one up... If it holds anywhere from a pint to a quart of fuel it shroud do the trick.... You could actually put a air bleed valve on it ti initally get it full and release al the air at time of installation...
Its just a chamber with two inlets and one outlet....
http://images.lmgtfy.com/?q=fuel+swirl+pot
Think this is sort of interesting...
http://www.mgexperience.net/archive/No_ ... ck/1702616
Dale
- yvre
Did you try at your local official VW dealership? That's where I bought mine.Max Welton wrote:Already been there Steve. That thread is how I knew to look for that particular part. What I'm saying is that those sites I found that list it, show it as out of stock. When I tried to order it from busdepot, they told me it was out of stock and they had no idea when it would be available again.
Max
- Max Welton
No. But if you got one, it's worth a try.
Was this recently?
Max
Was this recently?
Max
- yvre
That was one year ago, and it was in Europe. But it's always worth trying.
- GS guy
Always thought one of these would make a nice little surge tank:
https://www.cantonracingproducts.com/pr ... H-PETCOCK/
All 3/8" ports, should provide plenty of flow.
- Max Welton
Well it's been a while but I finally have enough parts to get started.
Max
Max
Sweet! Good luck can't wait to get mine on the go!
- Max Welton
Did a trial assembly of the bottom end this weekend and initial deck ranges from .000" to .005". So I won't need to trim the cylinders but will need either .040" spacers or copper head gaskets.
