MS-3 2110 Buildup
Moderator: Tom Notch
Re: MS-3 2110 Buildup
Post by Piledriver » Mon Sep 08, 2014 1:40 am
F-type, weatherpack is also F-type.
The crimper jaws will have 2 sizes per nest, the outer is to hold the insulation, inner the wire.
There's the version for dsub pins, http://www.amazon.com/Paladin-Tools-209 ... B000JJJ706
IIRC the larger sizes use Paladin 2033
These are for the Paladin crimp-all tools.
You may be able to get a dedicated one-size crimper for your immediate needs cheaper, but the Crimp-Alls rock.
One for weatherpack: has individual nests for various stages of the crimp, looks like it will cover most F-types:
http://www.amazon.com/Delphi-Packard-We ... B002CCAEJ6
Max Welton
Post by Max Welton » Mon Sep 08, 2014 5:25 am
Thanks!
Max
Steve Arndt
Post by Steve Arndt » Mon Sep 08, 2014 11:36 am
I have these, and about six other similar styles. Always make a few practice runs to get just the right jaw size for the crimp/wire.
http://www.adafruit.com/products/350?gc ... vAodYUMAiw
Max Welton
Post by Max Welton » Wed Sep 10, 2014 6:05 pm
I'm going to take a stab at using the VE table generator and I need some performance estimates.
To recap the engine, it's a 90.5x82 2110 with 3.325" rods. CR is 8.2:1.
The cam is an SLR EXV264Hyd on 106º lobe centers. Duration is 264º for both intake and exhaust with lift of .378 (.491 inches with 1.3 ratio rockers). The heads are worked autolineas with 38.5mm intake and 34.3 exhaust valves. Single HD springs. 1-1/2" exhaust (Vintage speed muffler). The TBs measure 36mm. Revs will be limited to 5k.
Any guesses what this will make at sea level?
Max HP @ what rpms
Max Torque @ what rpms.
Max
Max Welton
Post by Max Welton » Wed Sep 10, 2014 8:56 pm
OK, using 105 HP @ 5300, 115 ft/lbs @ 3250 and a redline of 5400 rpms, all at 100 kPa this is the map.
Max Welton
Post by Max Welton » Wed Sep 10, 2014 8:58 pm
And ... we have a tach signal from Mario's hidden trigger. ;-)
Max
MarioVelotta
Post by MarioVelotta » Wed Sep 10, 2014 11:03 pm
I use these alot, they are inexpensive and do a great job.
http://www.amazon.com/GM-Delphi-Weather ... S3GH42DH9R
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
MarioVelotta
Post by MarioVelotta » Wed Sep 10, 2014 11:13 pm
I have now worked with 2 of the vintagespeed exhausts. Neither one has fit properly... Kinda unfortunate for an otherwise nice and expensive exhaust system.
They are also really hard to tune at low speed and idle... I think it's the very large open chamber that allows lots of free air to mix at light loads.
Max Welton
Post by Max Welton » Wed Sep 10, 2014 11:30 pm
Yeah, my engine guy got a look at that picture and said he doesn't like the exhaust either. :-\
Since it's here, I may as well try it.
Max
MarioVelotta
Post by MarioVelotta » Wed Sep 10, 2014 11:44 pm
They sound good :)
He had to take this one back off after this and do some resealing to fix a couple exhaust leaks
Max Welton
Post by Max Welton » Thu Sep 11, 2014 5:26 pm
So I'd really like to know what these injectors flow in lbs/hour. I can't turn the numbers on the Pro Flow test sheet into anything that makes sense. When I asked Pro Flow for help they just offered to tell me if I would send the injectors back to them. :-\
So I've been hoping there is someplace I can just look up the specs based either on the injectors themselves or the original application. I'm coming up dry. The original VFR 800 application makes 110 hp @ 10500 rpm ( http://www.motorcyclespecs.co.za/model/ ... c%2006.htm ) so if you believe that HP is directly related to flow (and therefore fuel) these should be just what I need.
Now, the calculator at http://www.witchhunter.com/injectorcalc1.php says that a 110 HP 4-banger needs 17.2 lb injectors.
Thoughts?
Max
Max Welton
Post by Max Welton » Sat Sep 13, 2014 4:36 pm
Nuther question.
This diagram from http://www.msextra.com/doc/general/sparkout.html says the view is "into the coil". That still does tell me if the coil is above or below the connector.
So is this "into the coil" or do I have it upside down?
Max
andy198712
Post by andy198712 » Sat Sep 13, 2014 4:45 pm
is that for LS-1 coils or 2? (or another diagram?)
if you look at those diagrams the plug has a tab on it, i would use that as my guide to compare it to my plug.... if that makes sense?
Max Welton
Post by Max Welton » Sat Sep 13, 2014 4:56 pm
LS2. And the tab on the outside is what the connector clips onto. But there are also two tabs on the inside of the connector.
I am wary of hooking it up backwards (no good ever comes from that) and am hoping for someone to check me on this before I apply power.
Max
Max Welton
Post by Max Welton » Sat Sep 27, 2014 2:00 pm
Still having problems getting spark.
Mario has straightened me out on some wiring issues.
We are driving the LS2s from the expansion board according to the msextra diagram with 2, 3, 8, 12 and 17 all grounded to the 12v battery I am testing with.
http://msextra.com/doc/ms3/hardware.html#wiring-ms3x
On the LS2, A is ground, B runs to pin #7 (sensor ground) on the main board, C is pin 14 (for spark A) on the expansion board and D is +12.
No joy.
The hidden VR seems to be working fine and I get ~300 RPM cranking rpms.
Test mode on TS also does not generate a spark signal or light up the SPK3/4 - SPK1/2 indicator I put on my TS dashboard. Could someone running wasted-spark COP verify that this indicator works in this configuration?
I am stuck.
Max
