Speeduino ECU
Moderator: Tom Notch
Re: Speeduino ECU
Post by itawolf » Tue Jul 18, 2017 3:41 pm
that sucks bad
price wise it looked promising
RET Marine 0317 --with VW on the lobe!!
Lots of iron in the fire
Re: Speeduino ECU
Post by Piledriver » Tue Jul 18, 2017 5:40 pm
It still does, there's a V.5 board in the works that's ~all SMT and uses an automotive AMP connector.
Did they fix that routing issue on V.41 or .42 boards?
The bare boards are like $10 if you can DIY.
Properly done jumpers are not a cracking hazard, think SMT and wire wrap wire.
Re: Speeduino ECU
Post by kangaboy » Tue Aug 01, 2017 3:54 pm
So the only reason this has "hit a dead end" is because of a possible grounding issue? I'm still intruiged
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
Re: Speeduino ECU
Post by qaxa » Wed Aug 02, 2017 1:34 am
No it is not dead. I built one board earlier but it's not installed in a running engine yet. It does work however when I've tested it with a simulator.
Re: Speeduino ECU
Post by cnicholls » Thu Aug 17, 2017 9:47 am
I believe that the boards you purchase now are all fixed, I just happened to buy 4 boards with the flaw in it. Just don't order a version 0.4.1
