Mega Log Viewer Graph Scale
I've set up the MLV graphs for fine tuning the VE table and have actual and target AFR on one graph. The default setting is for the software to scale the Y axis independently for each of the traces, so because the actual AFR varies a lot more than the target AFR, the scales are different, so that that the 'overlay' is meaningless in terms of relative values between the graphs. Is it possible to fix the Y axis for 2 variables so they both show at the same scale?
Re: Mega Log Viewer Graph Scale
Calculated Fields -> Fixed Field Min and Max -> Add fixed field min and max.
Thanks a lot, sorted now.
