tunerstudio not connecting
ruff
Post by ruff »
Hello!
I just registered to tunerstudio because my laptop only has usb.
registered fine, but then still no connection to the ECU.
tried 2 usb cables... still no connection...
when i try to upload new firmware he tries the FDXX, but no connection possible
the usb ports on my laptop work... just used it with a HD...
ideas?
thanks!!
Re: tunerstudio not connecting
The FTDI needs the driver installed first to be usable, theres a link on the website.
The std RS232 serial works very well these days.(was recently rewritten)
Do make sure to first assign the USB serial device to a specific serial port#, the port detection in TS leaves much to be desired. (done in control panel>system>device manager in Windows)
That can be doe in Linux as well via a udev rule.
TS works much better with a known serial port.
(This includes the built-in adapter in MS3s)
Post by Chip Birks »
I just went through the same exact thing. New laptop, just had to download the drivers from DIYautotune. Not a big deal after that. I have tested on my MS3-Pro, as well as an MS2 with the adaptor. Works fine.
Jadewombat
Post by Jadewombat »
What are you using to crossover to a 9 pin? You have a USB to 9 pin adapter and software for the adapter? The lights are flickering on the adapter? You're hooked directly to the ECU (not a bluetooth), correct?
Dale M.
Post by Dale M. »
Check in Windows "device manager" to see what RS-232 port the USB adapter/cable is using... Might need to assign port number in tuner studio,,, Also check to see the there is NOT a "!" next to USB "device"...
Dale
ruff
Post by ruff »
yep,
it was a driver problem....
Solved now!!
profab
Post by profab »
Hey i hope im allowed to post links here. Its a useful guide for you that explains step by step.
https://www.diyautotune.com/support/tec ... nerstudio/
Should be very useful, i tried this myself as i had the same problems. Anyway for future reference in case another needs help you can always go there.
Hope it helps!
Custom parts, repairs and anything you can think of when it comes to repairing your car, a good place to go is Pro Fabrication. A reliable company from old cars to new.
