Cylinder Heads 044 size
Moderator: Tom Notch
Teo1303
Post by Teo1303 » Wed Mar 14, 2018 8:26 am
Hello everybody :)
My car is under restoration (floor-work at the moment) and after I bought everything for what I wanted for my car , I have bought recently 2 carbs ( 40 Dellorto DRLA) 1 set of 94x82 Mahle pistons-cylinders a crankshaft ( SSP 78 ) so the engine will be 2165cc ( 94x78) , 1 camshaft FK8 ( Engle )
Next I am going to buy a new case for 94 bore ( Auto Linea) rockers 1.3 and I got stuck with the size of my heads valves ... my engine also will be assembled with a full flow oil system
So which of these heads will be better for this set up of engine ??? the 044 ( 40x35.5 ) for 94 bore or the 044 oval port ( 42x37 ) for 94 bore??? :roll:
