Shoptalkforums.com
For Your Air Cooled Pleasure!
It is currently Mon Sep 06, 2010 1:13 am
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Brembos going on the square now
PostPosted: Fri Jan 29, 2010 8:57 am
Offline
well i have started the brembo conversion on the squareback now
hubs machined
bearing adapter and sleeve using vw inner and 944 outer
vw race installed
vw inner bearing and 944 outer bearing
test fitting hubs and rotors
test fitting calipers to see what i need to made for a adapter to mount them
Top
 Profile
 Post subject: Re: Brembos going on the square now
PostPosted: Tue Feb 02, 2010 4:10 pm
Offline
Are the hubs 944? Do you have any pics of the backside and how you mounted the calipers?
Top
 Profile
PostPosted: Wed Feb 03, 2010 8:45 pm
Offline
yes the hubs are 944... the rotors are from a 993 got a good deal on a set of front and rear . the only problem with the front one are. That they are 32mm thick. SO being they need to be resurfaced anyways had them turned down to 28mm and they slip in to the calipers now... I will take some more pics soon... still working on the caliper mounting. looks like i just have to relocate one mounting tab or weld on a extra mounting tab to mount the calipers. As soon as i get it done i will add more pic. of how i mounted them. right now i making sure i do not run into clearance issue with my wheels look like the calipers are going to be close.
Top
 Profile
PostPosted: Wed Feb 03, 2010 9:47 pm
Offline
Looks great so far!
Top
 Profile
PostPosted: Tue Feb 09, 2010 6:10 am
Offline
made the mounting bracket for the calipers today. I cut the mounting tabs off a set of 944 spindles trimmed them up and welding them to my stock typ3 spindles. test fitting everything on one side today...
Top
 Profile
PostPosted: Mon Feb 15, 2010 8:32 am
Offline
starting posting videos on youtube of this conversion
http://www.youtube.com/watch?v=-IT-0W1ehio
Top
 Profile
PostPosted: Sun Feb 21, 2010 1:12 pm
Offline
Looks good. 8)
Here's how I did mine..
Turned down a pair of old, stock discs - turned the disc-part down, so I basically had the hub only. So standard bearings could be used.
Then used 944 Turbo rear discs. As far as I recall they are 295x20,4 mm, and they slide right over the homemade hub.
Then I used the original upper caliper bolt hole, and moved the lower one a bit. I used the 72-> spindles for this, as the bolt spacing is the biggest.
Works like a charm!
Top
 Profile
PostPosted: Fri Mar 12, 2010 6:36 am
Offline
got the front brakes done now on to the rear
Top
 Profile
PostPosted: Sat Mar 13, 2010 2:10 am
Offline
Now, don't you look nice? :mrgreen:
Top
 Profile
PostPosted: Sat Mar 13, 2010 11:35 pm
Offline
Location: Undisclosed location...somewhere deep in the hinterlands
Dude, the wheels look fantastic! I love phone dials... good choice.
_________________
Josh
We come from dirt,
We return to dirt,
Circle of life, man.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
