Late T3 front brake upgrade--- BMW 2002Ti 4 piston calipers.
Moderator: Tom Notch
adjunog
Re: Late T3 front brake upgrade--- BMW 2002Ti 4 piston calip
Post by adjunog » Fri Nov 23, 2012 4:02 am
this was my local Volvo/Benz mechanic. I'm sure they can answer.
Black Forest Import Servicemore info‎
1342 Bowman Road
Mount Pleasant, SC 29464
(843) 849-9062
https://maps.google.com/maps?hl=en&clie ... IUBEPwSMAA
Post by Piledriver » Fri Nov 23, 2012 7:41 pm
All done, not really happy with the pedal feel after a good bleed, suspect it's a combination of a 16mm master cylinder, 3X the rubber brake hose and somewhat flexi floating calipers out back.
Cleaned up welds and secured the hoses/cables post picture.
The "16" on the side of the master surprised me, I'll be putting a std 19mm on.
aircooledtechguy
Post by aircooledtechguy » Sat Nov 24, 2012 11:41 am
Those Audi rear calipers look suspiciously similar to the calipers that all the aftermarket rear disc kits come with. . .
Post by Piledriver » Sat Nov 24, 2012 7:24 pm
Stupid Mityvac trick to the rescue:
Cut one of the old steel lines, hooked up to the mityvac to it, removed rear bleeders (10x1) connected the brake line and sucked on that with the mityvac, since it was sealed properly I was able to get a good draw/flow on the circuit, and sucked a ton of air out... apparently that high spot in the rubber line really likes to trap air.
The mityvac will suck air through the threads of the bleeder used the "normal" way.
Works good now.
Post by Piledriver » Sat Feb 23, 2013 4:58 pm
I ended up buying some Dorman speed bleeders for the back, much betta.
builtbychevy
Post by builtbychevy » Thu Mar 21, 2013 8:02 pm
I own a BMW 2002 race car I have plenty of new and used parts for them also considering I own a store. PM me if you want ANYTHING.
My Store: http://www.DirtyRacingAndRods.com
My Blog: http://blog.dirtyracingandrods.com/
If you can't run from John Law with it... It ain't no good!
Fiatdude
Post by Fiatdude » Fri Aug 01, 2014 11:03 pm
This guy did a first rate build and it has his brake solutions
http://www.shoptalkforums.com/viewtopic ... 1&t=141621
